Just got me a 97 LS and need Help/Advices!
Old Apr 3, 2004 | 10:01 AM
XyKo
Guest
Posts: n/a
Default Just got me a 97 LS and need Help/Advices!
I want to change the springs/Shocks because it seems hard and the original owner never fixed it. What brand should I check and how much?
Also, it's a manual transmission and my brother told me to change some fluids and stuff which I don't know. Anyone knows what he's talking about?
I'm trying to repair it, so it can last me a couple of months, while I learn how to master a manual car. Afterward when I feel confidence, I might be interested to hooking it up.
Also, there's seems to be water in my driverside headlights. How can I prevent water from getting in?
Thanks in Advance!
Old Apr 3, 2004 | 10:57 AM
Kendall's Avatar
Default Re: Just got me a 97 LS and need Help/Advices! (XyKo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XyKo &raquo;</TD></TR><TR><TD CLASS="quote">I want to change the springs/Shocks because it seems hard and the original owner never fixed it. What brand should I check and how much?</TD></TR></TABLE>
Utilize the search function. No one can tell you what is "best" and what will work best for you. You have to research it and perhaps do some experimentation.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XyKo &raquo;</TD></TR><TR><TD CLASS="quote">Also, it's a manual transmission and my brother told me to change some fluids and stuff which I don't know. Anyone knows what he's talking about?</TD></TR></TABLE>
The Manual Transmission Fluid is what he's referencing. It's popular to use GM Synchromesh in Honda transmissions due to the reduced wear characteristics associated with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XyKo &raquo;</TD></TR><TR><TD CLASS="quote">Also, there's seems to be water in my driverside headlights. How can I prevent water from getting in?</TD></TR></TABLE>
Common problem with Integra's. Remove the headlight assembly, bake it and separate it, let it dry completely, and then reseal it with clear silicone.
Old Apr 3, 2004 | 10:58 AM
King_j's Avatar
if the suspension feels hard, then thats a good thing.
tranny fluid change http://www.team-integra.net check in the article section
water in the headlight? is it cracked?
you may be able to use a silicone and seal it if its leaking at the glued point.
LOVE
Suspension & Brakes
Jan 29, 2009 03:04 PM
blackakkord
Jan 31, 2008 07:22 PM
MetalHead4454
Sep 11, 2005 09:35 PM
xxintegrlxx
Jun 16, 2005 11:32 AM
Godisintheradio
Nov 22, 2004 03:33 PM
