How does your car handle with B16 or B18?
Old Apr 3, 2004 | 08:57 AM
jtl's Avatar
jtl
Default How does your car handle with B16 or B18?
Just wondering if these swaps adversly effect handling. Thanks.
-Jake
Old Apr 3, 2004 | 09:09 AM
wtsexton's Avatar
Default Re: How does your car handle with B16 or B18? (jtl)
Handles fine, just goes faster! Then again I dropped ac too so maybe that balanced it out.
Old Apr 3, 2004 | 09:29 AM
SM 30 Hatch's Avatar
Default Re: How does your car handle with B16 or B18? (wtsexton)
I dropped AC and PS and the car still handles like it's nose heavy.. which it is..
I autox a lot and what not so I am tuned into these things, but I can't say that it handles poorly..
Old Apr 3, 2004 | 09:44 AM
4inspeed's Avatar
Default Re: How does your car handle with B16 or B18? (SM 30 Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SM 30 Hatch &raquo;</TD></TR><TR><TD CLASS="quote">I dropped AC and PS and the car still handles like it's nose heavy.. which it is..
I autox a lot and what not so I am tuned into these things, but I can't say that it handles poorly..</TD></TR></TABLE>
exactly, it wont handle the same as the stock motor, but then again it will still handle pretty good. you have to remember that with a ff car your entire drivetrain is in the front end. not to much wieght in the rear. so it will definately be nose heavy. but will still handle great.
Old Apr 3, 2004 | 10:06 AM
Charlie Moua's Avatar
Default Re: How does your car handle with B16 or B18? (4inspeed)
I wonder with the ProgressGroup Spring made specifily for EF with B swaps will make it handle better?
is it just a difference in spring rate?
Old Apr 3, 2004 | 10:12 AM
EG8R's Avatar
Default Re: How does your car handle with B16 or B18? (Charlie Moua)
ITR suspension heh Its one option of many.... Or get something made for an EF9/EF8. In other words, gt a suspension designed for a car with a B series engine....
Old Apr 3, 2004 | 12:06 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jtl &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering if these swaps adversly effect handling. Thanks.
-Jake</TD></TR></TABLE>
They don't, with the proper suspension setup.
I recommend Ground Control coilovers with custom spring rates for your needs, and Koni Sport dampers.
Don't do it the cheap way and buy a regular brand-name spring like everyone else here is recommending, because then you'll be stuck with spring rates you may not want. Do it right the first time.
Old Apr 3, 2004 | 12:57 PM
Patch's Avatar
Default Re: How does your car handle with B16 or B18? (Targa250R)
Ooh, my car is way tail happy. Probably because of the suspension, but thats just proof you can use suspension to balance out the weight and handling of the car. I'm running Konis/GCs with 425f/600r.
mtownek9
Oct 9, 2007 06:30 PM
HondaScott
Honda Civic (2001 - 2005)
Jul 4, 2006 07:12 AM
socalibur
May 31, 2006 04:41 AM
forever slow EG6
Jun 12, 2005 03:59 PM
wm5holla
Sep 24, 2003 09:10 PM
