greenish white flaky hard stuff is in the coolant passages of block? what is it?
Old Apr 3, 2004 | 07:52 AM
civicracer1993's Avatar
Default greenish white flaky hard stuff is in the coolant passages of block? what is it?
my friend has a block he got cheap and in all teh coolant passages it has hard white stuff built up// alot.. what is this and what does it mean? also how can it be cleaned out?
Old Apr 3, 2004 | 03:57 PM
Default Re: greenish white flaky hard stuff is in the coolant passages of block? what is it? (civicracer1993
up
Old Apr 3, 2004 | 04:20 PM
spaceman's Avatar
i think thats the dried up coolant but im not sure
Old Apr 3, 2004 | 04:28 PM
mugenracer's Avatar
If its green then its very possible that it is as spaceman said and just dried out coolant, just flush the whole head with hot water and detergent to get rid of it and it should be good to go!
Old Apr 3, 2004 | 04:58 PM
Lord Helmet's Avatar
it's called mineral deposit. that's what happen when you use plain old tap water and not the recommended distill water. all that build up eventually causes blockages in the coolant passages which will possiblity cause overheating or in extereme cases: blown headgasket or warped cylinder head.
ricerollz
11
Sep 22, 2010 07:29 PM
DjBij099
11
Apr 13, 2008 11:38 AM
obuhmyuh
Mar 3, 2008 11:53 AM
LSEGHATCH
Aug 18, 2005 12:33 PM
hatchy
Mar 18, 2003 04:20 AM
