How to Adjust Coilovers?
Old Oct 25, 2001 | 03:55 AM
Hiro's Avatar
Default How to Adjust Coilovers?
I want to raise my coilovers, but lost the tool. How do I adjust my coilovers?
Old Oct 25, 2001 | 05:13 AM
EP3_05's Avatar
Default Re: How to Adjust Coilovers? (Hiro)
You are going to have to get a new tool. If you have Ground Controls then you might be able to get another allen key from the hardware store. But if you have the normal coilovers with the dual locking perches, then you need the tool.
Old Oct 25, 2001 | 05:56 AM
markedOO1's Avatar
I lost mine too, a while ago and I just contacted someone who sells em and they were able to get me the wrenches pretty cheap...
Old Oct 25, 2001 | 03:42 PM
91ED7Si's Avatar
Default Re: How to Adjust Coilovers? (marked001)
what i want to know is how are you suposted to know if all four are completely even??
Old Oct 25, 2001 | 06:31 PM
MysteryWagon's Avatar
Default Re: How to Adjust Coilovers? (91ED7Si)
measure
Old Oct 26, 2001 | 02:09 AM
brad.'s Avatar
Default Re: How to Adjust Coilovers? (ShaggenWaggon)
yep....i usually count then number of threads from the bottom of the sleeve to the perches
Old Oct 26, 2001 | 01:49 PM
REDBARON's Avatar
Default Re: How to Adjust Coilovers? ([626]JDM-b16a-EF9)
Just use a tapemeasure. I just measure the distance from the bottom of the coilover sleeve to the bottom of the perch. Then I measure the distance from the ground to the edge of the fenderwell. Making sure the tapemeasure goes through the middle of the rim. But that's just me. Counting the # of threads is not very accurate, because that's what I use to do.
Old Oct 27, 2001 | 05:40 PM
neuspeed mafia's Avatar
New User
Default Re: How to Adjust Coilovers? (VTECHatch)
i count the rotations
E-motor USA
Aug 4, 2015 01:48 PM
BlueRex1020
Sep 28, 2006 10:06 PM
