timing belt help and others
Old Apr 3, 2004 | 04:43 AM
nbintegracing00's Avatar
Default timing belt help and others
i have a 00 gsr with 78k on it my timing belts looks like its loose like it somtimes when im makin a right turn sounds like its slaping againt the timing belt cover and also what are the thing you should look for in a worn timing belt o yea and sometimes when i take off in 1st there is like a sqeal noise from my right side it sounds like the brakes are stuck on the rotor or something can someone help me out thx
Old Apr 3, 2004 | 04:54 AM
doublejz's Avatar
Default Re: timing belt help and others (nbintegracing00)
hrm. if your timing belt was loose enough to slap your valve cover, you probably wouldn't have a operational vechile any more, you would be jumping teeth like crazy. If its only when you turn right you may want to check your axle could have a bad cv joint. The squealing could be your throwout/release bearing, does it only happen when you first let the clutch out when taking off?
Old Apr 3, 2004 | 05:01 AM
Default Re: timing belt help and others (doublejz)
sometimes when im not even turning left i can hear that nose it really souns like the blets is hiting the lower part of the cover if u look at it from the side the timing belt has some play in it and i just had all the bearings changed in my tranny yea it only does it when i let go of the clutch in first gear and if i hit second good you can hear if for a second just like a quik sqeak
Old Apr 3, 2004 | 07:59 PM
bump
invisible
25
Mar 16, 2007 09:49 AM
ShinobiLude
Feb 15, 2007 09:03 AM
greddytointegrate
Oct 15, 2005 06:05 PM
B_CRUZ!
Sep 9, 2003 12:20 PM
Sir_Phobos
Feb 22, 2003 08:56 AM
