Reseting the ECU ?
Old Apr 2, 2004 | 10:50 PM
es_squared's Avatar
Default Reseting the ECU ?
When is this necesary? and hows it done exactly.. ?
Old Apr 2, 2004 | 11:12 PM
iam7head's Avatar
Default Re: Reseting the ECU ? (es_squared)
there's couple of ways, the simplest is to pull the negative cable out of the battery for 5 second, put it back on and you're done.
another way is to pull the ecm fuse, but you need to wait for a little bit and you'll need to step on the brake panel couple of time.
Old Apr 2, 2004 | 11:20 PM
es_squared's Avatar
Default Re: Reseting the ECU ? (iam7head)
ok sounds easy, but are there any benifits to it or anythin? and when should it be done..
Old Apr 3, 2004 | 05:05 AM
doublejz's Avatar
if you had a CEL and you think your repaired the problem you should reset the ECU. The ECU keeps the CEL code in its memory.
For example, if you start your car and the CEL comes on, you shut it off and restart it and it doesn't come. (you would be like damn what was wrong). If you then jump the connector it should still have the CEL in its memory.
TwoKSiR
Engine Management and Tuning
Aug 1, 2009 08:05 AM
peanut butter
Jan 10, 2008 09:48 AM
liquidxEG
Feb 22, 2005 03:46 PM
genetsang
Jun 24, 2003 12:24 PM
