Impact gun on head bolts?
Old Oct 25, 2001 | 12:00 AM
dustin's Avatar
Default Impact gun on head bolts?
Head bolts are so hard to get loose... but something about using an impact gun seems like a bad idea. Afraid I will snap something off
Dustin
Old Oct 25, 2001 | 12:53 AM
paulzy's Avatar
Default Re: Impact gun on head bolts? (dustin)
just use a half of the bar for your jack as a breaker
Old Oct 25, 2001 | 12:56 AM
dustin's Avatar
Default Re: Impact gun on head bolts? (Slow_ass_4dr)
That is what I currently do... and it sucks
Old Oct 25, 2001 | 01:20 AM
immortal's Avatar
Banned
come on dont be a ***** :D, i took off like 1/2 mine the other day .....haha it was a struggle. i was pretty exhausted from just like 5 of them.
[Modified by immortal, 2:21 AM 10/25/2001]
Old Oct 25, 2001 | 07:00 AM
Speed PHreak's Avatar
Default Re: Impact gun on head bolts? (immortal)
HA HA HA...........lol breakerbar, OR use a small hammer and a socket. Put pressure against the bolt and tap frimly a couple of times, until you feel it move. I use this method often on stuborn bolts. Saves knuckles from being busted.
[Modified by Speed PHreak, 4:02 PM 10/25/2001]
Old Oct 25, 2001 | 07:35 AM
TurboT's Avatar
Default Re: Impact gun on head bolts? (Speed PHreak)
according to the manual..
you're supposed to go 1/3 turn at a time...
if you use an impact... i think you'll spin them off... and run the risk of warping the head.... correct me if i'm wrong...
Old Oct 25, 2001 | 08:03 AM
VaporTrail's Avatar
New User
Default Re: Impact gun on head bolts? (TurboT)
I only use an impact when the motor is cold, and I go in reverse order of proper install. Otherwise those fockers are tough! I've got a drawer of 3/8 14mm sockets that are broken from doing it, but I've never broken a head bolt.
Old Oct 25, 2001 | 08:09 AM
dustin's Avatar
Default Re: Impact gun on head bolts? (VaporTrail)
Haha, yeah I broke a 14mm socket just the other day on a head bolt. Cracked it straight down.
Dustin
Old Oct 25, 2001 | 08:26 AM
Uhhh, are you guys using standard sockets with an impact driver(air gun right?). There are 2 types of impact drivers, the pneumatic type like I suppose you're using and the "manual" type you hit with a hammer. You should be using impact sockets with either one, they're black colored and way stronger. I've never broken a socket before.......The manual type would better for breaking lose those head bolts b/c you can hit the thing as hard as you can and it will only spin the bolt about an 1/8 of a turn
looks like this
Old Oct 25, 2001 | 09:06 AM
dbman96's Avatar
New User
Have to use standard thinwall sockets because impact sockets don't fit into head bolt recess. At least mine don't. That's what craftsman lifetime warantee is for.
Old Oct 25, 2001 | 09:44 AM
DragII's Avatar
Default Re: Impact gun on head bolts? (dbman96)
I'm all about beating things w/ a big *** mallet.
Old Oct 25, 2001 | 09:46 AM
Default Re: Impact gun on head bolts? (DragIIcivic)
LOL
Old Oct 25, 2001 | 09:58 AM
VTC_CiViC's Avatar
Heh, broken 3 Craftsman 14mm sockets, 1 on the head, the other 2 on the rear suspension, 1 of which litterally split into 2 peices, the other 2 sockets just cracked right down the middle.
[Modified by VTC_CiViC, 2:00 PM 10/25/2001]
Old Oct 25, 2001 | 10:03 AM
rtype11's Avatar
use a big torque wrench, set it at 5lbs higher than tightening pressure and work slowly, 1/10th of a turn each bolt, 15lbs more if you used threadlock, you run the risk of warpage and bolt strecth if you go crazy with a johnson bar
Old Oct 25, 2001 | 11:52 AM
Adi Radoncic's Avatar
On Fire!
Default Re: Impact gun on head bolts? (rtype11)
What are those things torqed to anyways?
I loosened those up on my friends gsr with a 1/2 inch driver and I would literally have to take a 5 minute brake for every two nuts that I loosened.
Boy I'm weak
Old Oct 25, 2001 | 02:08 PM
SiR Kid's Avatar
New User
Default Re: Impact gun on head bolts? (newgsr)
Pussies Just use a big breaker bar you can buy at Autozone for like 25$... VERY good investment, and if you're steady with it and not jerky, then the bolt come off hella easy...
Old Oct 25, 2001 | 02:13 PM
quikrpm'z's Avatar
use a breaker bar with a pipe over it as a handle, much easier on the hands.
dustin's Avatar
I use impact sockets on the impact gun... But I use (and crack) regular sockets with just the breaker bar
Dustin
Old Oct 25, 2001 | 03:26 PM
Kamin's Avatar
cause your so damn strong dustin
lol
[Modified by KAMiN, 12:26 AM 10/26/2001]
Old Oct 25, 2001 | 03:44 PM
SiR Kid's Avatar
New User
Default Re: Impact gun on head bolts? (KAMiN)
Broken Craftsman sockets are a good way to get new clean ones
Old Oct 25, 2001 | 05:01 PM
dustin's Avatar
Hah, yeah I am super strong. You seen my pic? I look like I am 12 I used a 1/2" breaker bar + jack handle and cracked the freakin 14mm socket
Dustin
Old Oct 25, 2001 | 08:57 PM
bigTom's Avatar
use an impact socket (if ur breaking the regular sockets) or go buy a snap-on... i havent cracked any snap-on sockets from the headstuds yet and iv taken of a lot of heads... and then just use a breaker bar with about 1/3 to 1/2 turn increments (oh... and dont be a bitch about... like some of the pansy asses here! jk)
Old Oct 25, 2001 | 10:37 PM
VaporTrail's Avatar
New User
Default Re: Impact gun on head bolts? (ek9t)
I've broken them ALL. Strap on, S&K, Mac, Crapsmen, you name it, I've split them (all 14mm's by the way) EXCEPT FOR some small cheap company called Premier. These things I can't find for myself, but my friend who helps me at my shop got them as a gift and he hasn't broken one in 3 years. He said the whole set cost him like 40 bucks or somethin.
Old Oct 25, 2001 | 10:43 PM
lucas569's Avatar
jeez wtf are the head studs torqued at?
Old Oct 26, 2001 | 05:15 AM
rtype11's Avatar
this is nuts, why do you guys have all these problems with tight 14mm, the only time we cant get a stud off is if the head is warped. - you do use torque wrenches for the head studs right, if you dont your arp's dont do their job right, - torque specs are right on the install instructions.
