suspension problem!!!! HELP!!!!!
Old Apr 2, 2004 | 09:11 PM
urquidezj's Avatar
Default suspension problem!!!! HELP!!!!!
i have a 91 civic hatch and it has the B16 in it. i have a problem with my suspension though. i have coil-overs on it and i have the back passenger side all the way down but there is still a 2 to 3 inch gap between the tire and the fender. any ideas what can be causing this? it also sits low on the front driver's side. your help will be greatly appreciated.
Old Apr 2, 2004 | 09:36 PM
96-EJ6 B18C's Avatar
Default Re: suspension problem!!!! HELP!!!!! (urquidezj)
Spring not seated in the perch??? Can you provide more details?
Old Apr 2, 2004 | 09:48 PM
urquidezj's Avatar
Default Re: suspension problem!!!! HELP!!!!! (96-EJ6 B18C)
everything is the way is supposed to, it had a set of eibach springs that give like an inch drop, and it was the same. high on the passenger rear side and low on the front driver side. i checked if i put my coilovers wrong and they are all the same. i also checked for any hits that car might of had and it has none. i dont know what to do, i hate having a 4x4
Old Apr 2, 2004 | 10:20 PM
If you could post some detailed pics of the suspension and the car we may be able to be a bit more helpful but for now I out of ideas. 4x4 civics do suck!
Old Apr 3, 2004 | 08:53 PM
urquidezj's Avatar
i'll ask my buddy for the digi cam and post some pics
Old Apr 4, 2004 | 11:54 PM
millertime666's Avatar
you might have a bent frame
Old Apr 5, 2004 | 11:09 AM
urquidezj's Avatar
Default Re: suspension problem!!!! HELP!!!!! (millertime666)
how can i check? if i have a bent fram that is.
mr. robot-o
Aug 25, 2008 02:04 PM
markwitdada9
Apr 18, 2005 06:27 AM
crs
23
Jan 18, 2003 07:53 PM
hybridbmw
Jun 13, 2002 04:21 PM
