fpr is dry...
Old Apr 2, 2004 | 06:58 PM
Joel_MN's Avatar
Default fpr is dry...
The vaccum line to the fpr is supposed to be dry correct.
I mean, if i unplug it, and its wet, then i have a problem.
I only ask becuase im getting a cel 45 and trying to figure out why before i drop $60 on a shop scanner.
Thanks
Old Apr 2, 2004 | 07:07 PM
mmuller's Avatar
Mad Scientist
Default Re: fpr is dry... (Scribes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scribes &raquo;</TD></TR><TR><TD CLASS="quote">The vaccum line to the fpr is supposed to be dry correct.
correct if not your diaphram on the fpr went bad
check your 2nd o2 sensor
Old Apr 2, 2004 | 07:11 PM
Joel_MN's Avatar
Default Re: fpr is dry... (mmuller)
yeah, everything is pointing to the o2 sensor, which sucks *** cause there damn expensive.
Old Apr 2, 2004 | 07:25 PM
Sliced Beard's Avatar
if you were in charleston i would hook you up
i work at Auto Zone
Old Apr 2, 2004 | 07:44 PM
RTE117's Avatar
Yes.
Old Apr 2, 2004 | 11:28 PM
iam7head's Avatar
Default Re: fpr is dry... (IDriveAHonda)
the line should be dry, the diaphram(i can never spell it) is rip up like the guy said before
TheTealHatch
May 26, 2007 07:48 PM
honintegra
Nov 16, 2006 09:50 AM
eskimo_usd
14
Apr 26, 2006 08:27 PM
bspeed
Nov 16, 2004 04:22 PM
B00ST2nR
Mar 2, 2004 10:20 PM
