Crx Fogs up like crazy when it rains, Any suggestions as to why?or what I can do??
Old Apr 2, 2004 | 05:52 PM
Spooled1.6L's Avatar
Default Crx Fogs up like crazy when it rains, Any suggestions as to why?or what I can do??
All the windows fog up real bad I can barely see out of them, the only thing that I can think of is that my heat doesn't work and the difference in temparature is causing the fog up Let me know.
Also it does it even if its been sitting out all night I'll come out in the morning the whole god damn car is fogged up
Old Apr 2, 2004 | 06:04 PM
regime's Avatar
Default Re: Crx Fogs up like crazy when it rains, Any suggestions as to why?or what I can do?? (Spooled1.6L)
theres a lil selector button on the climate controller. put it on exterior air and not on recirculated.
Old Apr 2, 2004 | 06:09 PM
integraracing91's Avatar
Default Re: Crx Fogs up like crazy when it rains, Any suggestions as to why?or what I can do?? (regime)
Or you can try A/C if you have it, works everytime
Old Apr 2, 2004 | 06:26 PM
Default Re: Crx Fogs up like crazy when it rains, Any suggestions as to why?or what I can do?? (integraracin
Ill give that a whirl
Old Apr 2, 2004 | 09:31 PM
b16_madman's Avatar
keep a towel with you.... that's not by choice my a/c is not hung right now
Old Apr 2, 2004 | 10:34 PM
SC0TT's Avatar
Crack the windows a little.
Old Apr 3, 2004 | 10:57 AM
jayjay's Avatar
You have standing water some where in your car... I do believe that is why the fog won't go away...
Old Apr 3, 2004 | 11:23 AM
tylerdurden's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by regime &raquo;</TD></TR><TR><TD CLASS="quote">theres a lil selector button on the climate controller. put it on exterior air and not on recirculated.</TD></TR></TABLE>
This works.
Old Apr 3, 2004 | 11:28 AM
Targa250R's Avatar
be professional
Tips that work:
- clean your windows
- wipe down your windows with shampoo, then wipe off
- use the air-conditioning; it works as a dehumidifier and will clear up any fog within seconds
- open your windows if you don't have A/C (or if you were dumb enough to remove it if you did)
- keep your selector set for fresh air, not recirculated air
- check your car for water leaks (particularly in the rear) and seal them up
Old Apr 3, 2004 | 11:40 AM
EFParkwayRacer's Avatar
From: Bloomfield, New Jersey, United States of America
You have Rain water coming into your car somewhere by the firewall , If you feel under the rug by the computer its probably wet . Water usually comes in between the right front fender and hood by the windshield (under the plastic cowl cover ) . I had to remove my entire dashboard and heater box to fix this problem . Good Luck
Old Apr 3, 2004 | 12:04 PM
RCautoworks's Avatar
Default Re: Crx Fogs up like crazy when it rains, Any suggestions as to why?or what I can do?? (EFParkwayRac
Buy some anti fog stuff from rain x.
Old Apr 3, 2004 | 10:32 PM
Deff found the water, in the back of the car around the tired. it seems to be leaking in around the right rear Hatch Strut. I can see it drip drip driping down. I have no idea how to fix that
Old Apr 4, 2004 | 05:19 AM
crx si 2004's Avatar
ok here you go, the infamous crx problem,its prolly your sunroof take out your right or left side tail light cover, there should be a brown rubber drain hose thats prolly cloged. there are also drains in the front that come unconnected basically you just have to blow them out with an air compressor good luck
Old Apr 4, 2004 | 06:00 AM
b18crx's Avatar
Fogx? never tried it but may work
Old Apr 4, 2004 | 07:41 AM
FULL-RACE EP3's Avatar
Default Re: Crx Fogs up like crazy when it rains, Any suggestions as to why?or what I can do?? (b18crx)
hey man did you get that pig running??
Old Apr 4, 2004 | 11:16 AM
Default Re: Crx Fogs up like crazy when it rains, Any suggestions as to why?or what I can do?? (Pooptooth)
yea finally got the car running, Had to buy another motor though the one I got from you didn't work but the trans was nice So i got something out of it.
Also I DOn't have a Sunroof. I'll look for those drains but its like getting in someplace on the hatch cause I see it dripping in side from the right rear Strut that holds up the hatch. it drips right down onto the right rear speaker then just fills up the back
Anymore tips?
Old Apr 4, 2004 | 11:48 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spooled1.6L &raquo;</TD></TR><TR><TD CLASS="quote">Also I DOn't have a Sunroof. I'll look for those drains but its like getting in someplace on the hatch cause I see it dripping in side from the right rear Strut that holds up the hatch. it drips right down onto the right rear speaker then just fills up the back
Anymore tips?</TD></TR></TABLE>
Take some interior trim out, sit in your car and have someone spray a hose all over it. Check for leaks.
Check your hatch seal to make sure the rubber isn't torn.
Use some sealant around the rear washer nozzle and under the trim in the "rain gutters" on the roof. According to many leaky CRX owners, these are a common source of leaks.
Old Apr 4, 2004 | 12:13 PM
beavis's Avatar
when it rains my spare tire well gets water in it, I think its from the taillight seals, check that.
Old Apr 5, 2004 | 03:01 AM
Default Re: Crx Fogs up like crazy when it rains, Any suggestions as to why?or what I can do?? (ZCed89hatch)
It could be from the tail lights, but I actually SEE with my own eyes water dripping in right off the base of the Right Rear hatch strut. And it runs down the speaker into the rear compartment
Old Apr 5, 2004 | 04:07 AM
deftones0817's Avatar
I have myi right and left hatch strut doing that. If you figure out how to fix let me know. Come on guys give us an answer...also i have after market ones with screws in them if that helps solve the problem???
DEF
Old Apr 5, 2004 | 04:57 AM
Default Re: Crx Fogs up like crazy when it rains, Any suggestions as to why?or what I can do?? (deftones0817
hmm too add to this real quick. and Im sure it doesn't matter but my struts are blown so I have to replace them anyway. anyone know where I can get some cheap replacments?
1slowEK
Oct 12, 2007 08:47 AM
jeezyskillz
Nov 14, 2006 11:38 AM
ne3ek
Jan 5, 2006 09:27 AM
CRX Si
Mar 28, 2005 09:15 PM
kron0ne
Dec 4, 2003 11:52 PM
