whats causing car to leak from here???
Old Apr 2, 2004 | 04:05 PM
Disco Monkey's Avatar
Default whats causing car to leak from here???
where could the water most likely be coming from?
just wondering if someone else has has this same problem.
i thought the sunroof was the cause at first, but now i have a fiberglass filler and its sealed up tight.
my only guess is maybe the water is getting in through the roof mouldings.
location is a hole between sunroof and rear hatch right above both rear windows
here are some pics
Old Apr 2, 2004 | 05:22 PM
type Gendy's Avatar
Default Re: whats causing car to leak from here??? (Disco Monkey)
This si gonna be a LOOONG WEEK with all of the rain. My car is soaked >
Old Apr 2, 2004 | 05:37 PM
^jefs0ng's Avatar
Banned
Maybe from the top of the hatch?
Old Apr 2, 2004 | 05:58 PM
DC 2's Avatar
Default Re: (^jefs0nq)
Sometimes the drain tubes will get clogged and cause a leak. Make sure everything is clean.
Old Apr 2, 2004 | 06:01 PM
type Gendy's Avatar
Default Re: (EH3B18B)
I have heard of this happenign on crx's with no sun/moonroofs, which would mean they have no drain tubes, right?
Old Apr 2, 2004 | 06:05 PM
EightNine's Avatar
I had a problem with water getting into my car that I thought was related to the moonroof, but it turned out to be a faulty seal around my windshield. I seriously doubt water would travel along the roof of your car and fall from that far back but you never know. There are really only three places (that I can think of): the drains on the moonroof, the windshield or possibly the hatch.
Old Apr 2, 2004 | 06:24 PM
jspek29's Avatar
Default Re: whats causing car to leak from here??? (EightyNineSi)
bumping this up , cause i had the same prob in my other crx, i always had water collecting where the spare tire was, havent rain enough to see prob in this crx. but i suspect its from where u think it is
Old Apr 2, 2004 | 06:37 PM
Default Re: whats causing car to leak from here??? (jspek29)
the sunroof is gone. so are the drain tubes. i originally thought all that was the cause of it, but i guess not.
the only place i think water may be getting in is the "roof mouldings" that run on the top of the roof on each side. or it might be coming from somewhere around the rear glass...maybe some seal back there or the area where the hatch bolts on to the car.
Old Apr 2, 2004 | 06:53 PM
ls_vtec_crx's Avatar
yeah mines leaks too and there's no sun or moonroof....i thinks thats the spot where its leaking from...
Old Apr 2, 2004 | 06:59 PM
EightNine's Avatar
Default Re: (ls_vtec_crx)
I turned the water hose on low and let it run over different areas on top of my car until I figured out it was the windshield. Maybe when its dry outside you could do the same to get a better idea of where the leak may be from. I know it sucks for water to get in. I used to literally pick up gallons of water with my wet/dry vac after heavy rains.
Old Apr 2, 2004 | 07:13 PM
wow mines isnt that bad....mines just drips kind of constantly....only while its raining though
Old Apr 2, 2004 | 07:18 PM
Targa250R's Avatar
be professional
Try pulling the trim out of the two "rain gutter" seams on your roof, and using some sealant in there. I've heard of many people stopping leaks this way.
Old Apr 2, 2004 | 07:47 PM
fs's Avatar
fs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Disco Monkey &raquo;</TD></TR><TR><TD CLASS="quote">where could the water most likely be coming from?
Do you have a rear wiper on your hatch? The nozzle that sprays the washer fluid can leak. Try pouring water around the nozzle and see if it leaks.
Based on the pictures and my own currently stripped rex, that'd be my best guess as to where the problem is coming from. There's no way to get at the nozzle from inside the car (as far as I know), so if that IS the cause, I'd suggest you pop the nozzle up and reseal it with some silicone.
Old Apr 2, 2004 | 08:22 PM
Default Re: whats causing car to leak from here??? (fs)
i will have to try the area around the nozzle...this seems like it could be it.
thanks for the suggestions
Old Apr 2, 2004 | 08:43 PM
insomniac791's Avatar
Mine leaked as well I put silicone in teh gutters along the roof and silicone around teh rear squitter that was about 8 months ago and no leak since. Mine leaked bad before I did it too.
later
Matt
Old Apr 2, 2004 | 09:16 PM
Dran's Avatar
My 89 leaks in the exact same place.....I thought it was the sunroof also!
Old Apr 2, 2004 | 09:27 PM
Default Re: (Dran)
do the rain gutters just pop off?
i guess ill try to get them off and silicone them tomorrow.
also how do you remove the squirter? just pull up on it?
Old Apr 3, 2004 | 12:43 AM
Lamchop0000's Avatar
my rear interior is complete striped and...
during winter my whole trunk was filled with water, when i hit the brakes it would rush up and wet up the back of my seat...
then i saw alot of water in the inside of the tail lights.
so i took them off and put some silicone sealent on the taillights and bolt holes. then it reduced the water tramendusly!
try that out! HTH
Old Apr 3, 2004 | 01:55 PM
Default Re: (lamchop0000)
ok i put sealant on the rear winshield squirter...waiting for it to dry now.
i pulled off one of the rain gutters...for some reason i thought that it was a seal, but there was nothing to "seal". so water is not coming in from the rain gutters.
hopefully it was coming from the squirter.
Old Apr 3, 2004 | 02:29 PM
kron0ne's Avatar
Default Re: (Disco Monkey)
i got that problem but only when it sits through the snow...my interior light fills up
G. spear
Old Apr 3, 2004 | 07:40 PM
fs's Avatar
fs
Let us know if it works.
You just popped the nozzle up, then put sealant on it, right?
Old Apr 4, 2004 | 12:54 PM
Default Re: (fs)
well i still have the leak. i used the water hose and just ran water over the squirter area and it took a few minutes but the water eventually started leaking in (but the water was also running down around the hatch too, so water maybe coming from hatch bolts).
maybe i didnt seal the squirter up well enough...so i just put more sealant around it. so i am waiting for that to dry.
and then i will test it again
Old Apr 6, 2004 | 03:32 PM
i found the leak
it was right behind where the rain gutter stops and right in front of the rear hatch...in that valley that runs around the hatch
there was a big crack in the body.
i just put sealant on it and waiting for it to dry.
im pretty sure the was the cause.
thanks for the help everyone.
hope there are no more undiscovered cracks anywhere
Old Apr 6, 2004 | 05:38 PM
racerxb18b's Avatar
a lot of times the water gets in by the rear hatch struts. mine used to fill up the spare tire well pretty good.
Old Apr 6, 2004 | 06:47 PM
type Gendy's Avatar
Default Re: (racerxb18b)
I was thinking about pulling up the rubber modling going down the roof line, i think there is a weld/seem under there? Anyboyd know for sure? PUll that up and put a bead of silicone down there and then glue the molding back on...
green91
12
Feb 1, 2006 11:00 AM
Wasabithegosu
33
Jun 21, 2005 01:35 PM
djdizzo
Jan 22, 2005 04:10 PM
civicracer1993
11
Sep 16, 2003 07:57 AM
GroundZer0 336
Mar 15, 2003 05:29 AM
