converting to rear discs from 6th civic to teg
Old Apr 2, 2004 | 02:26 PM
pearlcfcivic97's Avatar
Default converting to rear discs from 6th civic to teg
can someon tell me absolutely everything that i would need to convert my rear civic drumb brakes to integra rotors i know you need rear lower control arms...the rotors and calipers and im just curious what everything is...
brian
Old Apr 3, 2004 | 09:31 PM
Old Apr 4, 2004 | 10:06 AM
miahmouse's Avatar
Default Re: converting to rear discs from 6th civic to teg (awdturbolaser03)
it's easier if you get em off a 99-00 si. only have to change: si trailing arm assembly, si brake lines, si e-brake cables. You should change: si prop valve. if you dont' have an ex you may want to change MC&booster. if you're set on using teg parts check out this thread https://honda-tech.com/zerothread?id=641639 don't forget the flare nut wrench...
btw. search is your friend
Old Apr 4, 2004 | 12:57 PM
piscorpio's Avatar
Got my conversion from a 94-01 Integra (non-Type R, if it is type R, there is more changes involved). It came with trailing arm, upper control arms (not sure if those are necessary though), e-brake cables, rotor, calipers, etc. It was all pretty straightforward, remove old stuff and bolt up new stuff. The biggest obstacle, especially with older model Civics in extreme climates, is siezed bolts and similar problems caused by rust and weathering. Have alot of PBlaster, WD40, etc., a torch and good size breaker bar on hand.
Old Apr 4, 2004 | 04:27 PM
yeah i know all about stupid seized bolts there a pain in the *** but you just got to be patient thanks for all the help...
lxdriver
Suspension & Brakes
Mar 8, 2013 11:47 PM
StatGSR
Suspension & Brakes
10
Jun 12, 2005 07:48 PM
damn_import_culture
Jan 1, 2005 01:07 AM
