LS swap into CRX
Old Apr 2, 2004 | 01:34 PM
Jules Winnfield's Avatar
Default LS swap into CRX
anybody out there in H-T land kno how to wire up the LS motor harness into the CRX car harness?
Old Apr 2, 2004 | 03:36 PM
racerxb18b's Avatar
Default Re: LS swap into CRX (89cr-ls)
more info needed
which ls a or b
which crx do you have hf dx si
or just use the search button
Old Apr 2, 2004 | 05:03 PM
ThaReason's Avatar
What model id your rex? What year is the motor? If u have a Si then just use your complete Si harness.
Old Apr 6, 2004 | 07:39 AM
Default Re: (ThaReason)
sorry i didn't give enough info b4, i was tired. anyway the crx is a HF and the motor is a 94 b18b. since the trans is hydro, i just ordered the Hasport mounts and shift linkage. the mounts should be here any day and i want to drop the motor this weekend but i don't want to run into any problems wiring the ecu. all help is very appreciated.
Old Apr 6, 2004 | 08:07 AM
bambam's Avatar
if ur running the obd0 pr4 ecu then just slap on ur HF wiring harness onto the teg motor. U'll prolly have some plugs left over tho from the HF harness.
Old Apr 6, 2004 | 08:35 AM
carfreak82's Avatar
from my under standing if you go with the 90 ls swap the harneses should match up
Old Apr 6, 2004 | 05:17 PM
untitled's Avatar
Default Re: LS swap into CRX (carfreak82)
you don tneed to wire anything. just use a 90-91 obd0 ls distributor,obd0 pr4 ecu, and obd0 injestors with your stock hf harness. there is one thing. the coolant sensor on obd1 engines is on the termo housing, on obd0 its in the back off the block. youll have to lengthen the plug over to the thermohousing.
thanx for playing!
Old Apr 6, 2004 | 08:29 PM
SlowSpoolin1.6SOHC's Avatar
Default Re: LS swap into CRX (vetter)
So on a 91si the harness will also plug right up, but with the pr4 ecu?
Old Apr 6, 2004 | 08:42 PM
untitled's Avatar
Default Re: LS swap into CRX (SlowSpoolin1.6SOHC)
obd0 ecu will plug into obd0 harness bro
Adam Silkwood
Jan 21, 2013 01:14 PM
Jackson_Si
11
Jun 19, 2008 08:29 AM
STP_crx123
May 31, 2006 07:14 AM
mrtony86
20
May 25, 2006 06:03 AM
HondaSP
Jul 7, 2002 12:22 AM
