Suggestions please...about a huge freakin vacuum leak
Old Apr 2, 2004 | 01:17 PM
95 integra's Avatar
Default Suggestions please...about a huge freakin vacuum leak
Problem fixed, leak around the TB gasket...actually i used the wrong year TB gasket.
Ok, so Ive got a high idle now that Ive rebuilt my motor, so I start with the usual stuff and go for the IACV and fast idle thermo. Well after no luck there, I decided to put my hand OVER the TB and see if it would die down(stall hopefully). It didnt do ****...still idles at 1200 rpms, thus, Ive got a big vacuum leak, but Ive checked all my connections and hoses, sprayed brake cleaner and didnt see it, I used new IM gaskets and Im out of ideas. Anybody got an idea where a rather large amount of air could be coming in at?
Modified by 95 integra at 10:29 PM 4/7/2004
Old Apr 2, 2004 | 03:57 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Suggestions please...about a huge freakin vacuum leak (95 integra)
Well the biggest vacuum hose I think is the one going to the brake booster.
Old Apr 2, 2004 | 04:09 PM
PissedoffGS-R's Avatar
Your sure all your vacume lines are hooked up? Theres not one in some shadowy dark area of the engine bay you cant see just hangin? Are your brakes working good?
Old Apr 2, 2004 | 05:10 PM
95 integra's Avatar
Default Re: Suggestions please...about a huge freakin vacuum leak (PissedoffGS-R)
Ok, how about surging...with the IACV hooked up the idle surges(I assumed fixing the high idle would fix the surging crap). Anyway, I cant find anything, Ive taken the IACV and the fast idle thermo off, cleaned them and checked to see if they work or not. The **** just doesnt work.
Old Apr 4, 2004 | 10:17 AM
deepgreengsr's Avatar
well if there is a vaccume leak and you didnt find it with carb cleaner, i bet its the break booster(stated above) and its leaking internally. unplug the line and cap it with a bolt and see if the leak goes away.
Old Apr 4, 2004 | 11:38 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote"> sprayed brake cleaner and didnt see it, </TD></TR></TABLE>
Did you spray where the manifold meets the head? It's easy to miss a peice of the old gasket. A vacuum leak that big shouldn't be too hard to track down.
Old Apr 6, 2004 | 05:38 PM
95 integra's Avatar
Default Re: Suggestions please...about a huge freakin vacuum leak (Chiovnidca)
actually it was the TB gasket. I used one for a 96+ that doesnt have the fast idle thermo(i think thats right) and the gasket didnt have the lower ports(or even a gasket down there) so it was sucking air right there at the bottom where there wasnt a gasket.
Old Apr 7, 2004 | 01:20 AM
Bay_707's Avatar
sorry i have to laugh at your signature about the abs pump hahaha. I had the same problem... sounds like a cat or something... just take out the abs fuse
Old Apr 7, 2004 | 07:16 PM
Old Apr 7, 2004 | 07:17 PM
Default Re: Suggestions please...about a huge freakin vacuum leak (707_Eclipse)
that buzzing from the abs 100% means that the pump is ead or its just out of fluid.
Old Apr 7, 2004 | 07:28 PM
95 integra's Avatar
Default Re: Suggestions please...about a huge freakin vacuum leak (deepgreengsr)
actually its the modulator, which means I either have a gas leak or the pump isnt pumping very well. Either way, my abs still works(or atleast any time I needed it to) and my fluid is topped off.
Old Apr 12, 2004 | 12:08 AM
Bay_707's Avatar
my pump leaks like a no other... after 2 seconds of filling it up with abs fluid its all gone. so until i get the pump put in then its no abs for me
ArrowCD5
Apr 9, 2016 04:50 AM
BlackJacket
Dec 16, 2013 02:52 PM
cmsoard
Apr 1, 2009 10:15 AM
nus_dogg
Dec 29, 2008 08:32 PM
MtnCRX
Jun 5, 2005 06:16 AM
