Ground control Neuspeed koni question~~!
I have ground control's currently and i'm thinking of buying either kyb's or the neuspeed koni's...if i buy the koni's would they fit my g/c or would i have to buy adapters or something to fit them? same with the kyb's?
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ANGELIQUE »</TD></TR><TR><TD CLASS="quote">I have ground control's currently and i'm thinking of buying either kyb's or the neuspeed koni's...if i buy the koni's would they fit my g/c or would i have to buy adapters or something to fit them? same with the kyb's?
Thanks
Konis require the extra adapter ($10 per corner) to be used with the standard Ground Control sleeves. Ground Control also makes Koni-specific sleeves, so if you anticipate that you'll never run any damper other than Koni, you can opt for those - though they are no cheaper than getting the standard kit with the separate adapters.
KYB AGX do not require an adapter to be used with GCs.
http://www.ground-control.com/...48f28
http://www.ground-control.com/...b7e9f
Thanks
</TD></TR></TABLE>Konis require the extra adapter ($10 per corner) to be used with the standard Ground Control sleeves. Ground Control also makes Koni-specific sleeves, so if you anticipate that you'll never run any damper other than Koni, you can opt for those - though they are no cheaper than getting the standard kit with the separate adapters.
One Bad GeeSeeR
May 4, 2004 08:38 PM
