Drum brake piston help
Old Apr 2, 2004 | 10:08 AM
RCautoworks's Avatar
Default Drum brake piston help
Just wondering if you guys have any tips on holding this piston while trying to stretch the upper return spring ?
Old Apr 2, 2004 | 11:49 AM
showbiz's Avatar
Default Re: Drum brake piston help (90blackcrx)
what are you trying to do ? are you talking about the wheel cylinder ?
Modified by sedanman at 9:08 PM 4/2/2004
Old Apr 2, 2004 | 11:58 AM
Default Re: Drum brake piston help (sedanman)
Yeah, every time I stretch the upper return spring on the piston in the wheel cylinder wants to pop out.
Old Apr 2, 2004 | 12:08 PM
showbiz's Avatar
is the shoe sitting in the groove of piston? do you have the shoes secured with the spring clips? how are you streching the spring in place?
Old Apr 2, 2004 | 01:51 PM
Yes I have it secured but it still moves, I am using vice grips to stretch it.
Old Apr 3, 2004 | 09:05 AM
showbiz's Avatar
use a long thin flat head screwdriver ,loop/hook it on the end of the spring and put the tip of the screwdriver where you want the spring to go and then push out sliding the spring end into the shoe. sorry it's hard to describe
Old Apr 3, 2004 | 09:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sedanman &raquo;</TD></TR><TR><TD CLASS="quote">use a long thin flat head screwdriver ,loop/hook it on the end of the spring and put the tip of the screwdriver where you want the spring to go and then push out sliding the spring end into the shoe. sorry it's hard to describe</TD></TR></TABLE>
I understand that, the vice grips actually work better. When your pulling the spring, the shows have a tendency to move pushing the one piston in. I am just gonna use c clamps.
exgr
18
Oct 29, 2010 02:14 PM
iLOVEmyEMone
Suspension & Brakes
Oct 19, 2005 11:07 AM
D3U1LT
10
Jan 12, 2005 12:20 PM
RCautoworks
18
Jul 30, 2003 02:02 PM
