(4th gen) 5-speed swap - any firewall modification required?
Old Apr 2, 2004 | 07:03 AM
Greyout's Avatar
Default (4th gen) 5-speed swap - any firewall modification required?
Am I correct in assuming that you simply can swap the hardware over, without modifying the firewall at all? The bolt holes & what not for the clutch cylinder already exist?
btw, this is on a 4th gen ... TIA
Old Apr 2, 2004 | 09:13 AM
Greyout's Avatar
Default Re: (4th gen) 5-speed swap - any firewall modification required? (Greyout)
its been done before, right?
Old Apr 2, 2004 | 11:42 AM
luder94-ChrisA's Avatar
No firewall modification/cutting/etc. is required. Just make sure you have all the parts - including the clutch lines for the slave & master cylinders. When I did my five-speed swap, we took all the parts off a salvaged car which I bought from an auction. That way, I just unbolted all the parts from one car & saw exactly where to bolt them right up on my car.
Old Apr 2, 2004 | 02:12 PM
Greyout's Avatar
Default Re: (4th gen) 5-speed swap - any firewall modification required? (luder94si)
well, its not fresh in my mind, as i took everything off about 6 months ago - but I did keep all the parts so I'm expecting it to go rather painless.
Is it possible to do it without taking the dash off? I took the dash off when I took the parts off, but I was being a bit careless with some of the trim and would rather avoid that for now.
Old Apr 2, 2004 | 04:53 PM
skrewdlude's Avatar
Yea, I didn't have to take my dash off. It was fairly simple to do. If you have the motor out, then it is incredibly easy to run the lines. I think getting all the manual crap in the car only took me a couple of hours, like I say it wasn't bad at all.
Josh
jealous1shateric
Northeast (Sales)
Sep 29, 2014 02:10 AM
Si Speed
Nov 29, 2007 07:27 AM
cb9_MIke_F22a6
Jun 8, 2006 08:13 PM
iCe_2x
Apr 29, 2005 10:53 AM
