Hey what 2inch drop springs have the highest spring rate??
Most Drop Springs are Progressive rates not linear so getting a high spring rate from them would be tough. I would look into some ground contols where you can choose the rate.
order custom rate Eibachs from Ground Control...make sure you have Koni Yellows if you go this high with rates.
Tweak, who's 400/500 on Koni Yellows full stiff, and has *mad* chasis reinforcements from the DC2's weak body flexing.
