Type R intake manifold?
Old Apr 1, 2004 | 09:32 PM
jdmcivicferio's Avatar
Default Type R intake manifold?
Does anyone have the dimension of a Type R intake maniold, such as the length width etc, also what size does the plenum start off as 62mm?
thanks
Old Apr 2, 2004 | 07:22 AM
mikestypeR
Guest
Posts: n/a
Default Re: Type R intake manifold? (jdmcivicferio)
SEARCH does wonders!
if i had it i would post it but i dont know all that technical ish ..... good luck
Old Apr 2, 2004 | 07:34 AM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone have the dimension of a Type R intake maniold, such as the length width etc, also what size does the plenum start off as 62mm?
thanks </TD></TR></TABLE>
From http://autopedia.com/Acura/97_TypeRPowertrain.html
THROTTLE BODY & INTAKE MANIFOLD
In the interests of high rpm, high output and weight reduction, the Type R utilizes a large-diameter throttle body and exclusive single-port intake manifold. The throttle bore has been increased by 2 mm to 62 mm to allow for increased intake flow.
The cast aluminum intake manifold features a large-diameter, single intake runner for each cylinder with a short, direct path to the cylinder head for maximum high-rpm efficiency. The single-port design also results in a 3.2 kg weight savings. Also, the fuel injectors point almost directly toward the center of the intake valves, helping to reduce fuel condensation on the intake port walls and improving driveability and engine response. To ensure a large amount of cool, fresh intake air, the air inlet has been molded from the engine compartment to an area behind the left-front fender.
To substantially increase flow, the intake runners have increased 7 mm in diameter from 35 mm to 42 mm.
Old Apr 2, 2004 | 10:26 AM
Chris's Avatar
Default Re: Type R intake manifold? (zygspeed)
see sig for IM for sale!
$125 shipped!
Old Apr 2, 2004 | 11:10 AM
Chiller's Avatar
Im selling a skunk2 IM practcly new IM me if youre interested.
Old Apr 2, 2004 | 11:20 AM
still didn't answer my question..... You can't always find what your looking for when your search.....
Old Apr 2, 2004 | 11:24 AM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio &raquo;</TD></TR><TR><TD CLASS="quote">still didn't answer my question..... You can't always find what your looking for when your search.....</TD></TR></TABLE>
So, you're looking mostly for overall exterior dimensions?
Doing some type of swap/fabbing?
Old Apr 2, 2004 | 11:28 AM
Chiller's Avatar
62 yes. if its really important. I can take it out of the box i packed it up in. Its all ready to ship out and i can take pics etc. but its a skunk2 ITR mani
Old Apr 2, 2004 | 02:08 PM
dfoxengr's Avatar
Default Re: (Chiller)
i am wondering the same thing, runner lengths, plenum volume etc.
Old Apr 3, 2004 | 12:11 AM
Default Re: (hybridvteceg)
nevermind found out the dimensions I was looking for....
Old Apr 3, 2004 | 10:30 AM
dfoxengr's Avatar
Default Re: (jdmcivicferio)
can you share?
Old Apr 4, 2004 | 08:40 PM
the port size are the same as the h22, and the manifold is 10.5 inches long, the plenum will be good size to and the primaries are bigger then the b16, making it better for the high rpm so I am going to fab this onto my h22
Old Apr 4, 2004 | 08:53 PM
mikestypeR
Guest
Posts: n/a
i heard the AEBS intake mani makes more power than the ITR mani.....
Old Apr 4, 2004 | 09:10 PM
dfoxengr's Avatar
ive asked before and i gues NOONE knows the length of the runners and the width, or volume of the plenum?
tmrtwo
Dec 25, 2006 08:53 PM
biggdogg
Sep 21, 2006 03:31 PM
tech0937
Aug 5, 2005 09:06 AM
ThinHoanG
22
Apr 20, 2005 08:39 PM
EleanoR
Nov 25, 2001 10:09 PM
