Makin loud noise from the powersteerin of a h22.
yea juss like my otha topic i juss post up, i juss drop a h22 in to my 92 accord and i had to take out the power steerin to get the the alternator, so i took out the hose and some of the fluid leak out, so after i was done i juss screwed it bak together, and now its makin a loud strikkie noise. so if dere is air in the tube, how would i be able to fix dis problem with out any otha problems?
do a stress test(just read/learn about it today) on the ps system.
put a/c on to max, step on the brake panel to the ground, and then turn the s. wheel, it should turn turn as soon as you turn the wheel.
and when you turn it does it make an annoying low humping sounds.
come back and we'll start from there.
yea, it makes a loud striking noise wen i turn the steerin wheel in any direction, it mostly makes it wen the cars not in motion. and wen i put up the hood and look at the power steerin while im turnin the s. wheel it seem to struggle and shack a lil while that noise become louder.
