Hardwiring Radar Dectector when it is mounted by rearview mirror?
I want to know whats the best place to hardwire my radar detector when it is mounted below the rearview mirror? I was thinking about wiring it to the clock but i dont know if i can do that. Also, i want to add a switch in the spaces right by the E-Brake. This i can do but i just wanted to add that so you'll would have an idea of what i am trying to do.
Thanks In Advance
Thanks In Advance
They have a wiring kit I can buy for like 10 bucks. I am going to get that. It goes threw the fuse box. Here's the link http://www.whistlergroup.com/o...t.asp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GS-RLover »</TD></TR><TR><TD CLASS="quote">They have a wiring kit I can buy for like 10 bucks. I am going to get that. It goes threw the fuse box. Here's the link http://www.whistlergroup.com/o...t.asp</TD></TR></TABLE>
horrible thing to do. Poor connection, and screws up the fuse box connection if you ever want to remove that extention. Just cut off the cigarette lighter end, extend the wires, and splice in with the wires behing your radio.
Yeah, that's a poor connection. I tapped the cigaret light / power adapter wire for my hard wire. I'm running an 8500 with the hardwire kit. I used the cig, because that's were it normaly plugs into, so it can handle the load; and since that wire is run through the factory wire looms, I was able to make a nice connection and zip tie the wire securely throught it's length at the factory locations.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer »</TD></TR><TR><TD CLASS="quote">Yeah, that's a poor connection. I tapped the cigaret light / power adapter wire for my hard wire. I'm running an 8500 with the hardwire kit. I used the cig, because that's were it normaly plugs into, so it can handle the load; and since that wire is run through the factory wire looms, I was able to make a nice connection and zip tie the wire securely throught it's length at the factory locations.</TD></TR></TABLE>
8500 has a hardwire kit? i just used a telephone cord....
http://www.escortradar.com/accessories.htm
Yeah, check it out, about 1/2 way down the page: "Direct Wire SmartCord"
I have the mute/led smart cord piece mounted to the top of my steering column. That way, I can run the unit in full dark mode (at night), and still see the alarm led even if I mute it. It's awesome, nobody on the road will know your running a detector.
*EDIT* Sorry - forgot the link....
Modified by EX_AutoXer at 3:54 PM 4/9/2004
i used a cheapo amp kit when i put neons underneath my dash
so i just ran the cord positive to the power loop i attacthed my neon wires to and grounded it to a screw worked like a charm
