Where to get a o2 sensor for cheap?!
you could get the universal from autozone for $60.00 bucks. all you have to do is either cut and splice the wires and connect using the connector they supply or solder the wires (preferred). spending 60.00 extra dollars for a connector is pretty retarded IMO. i installed one last weekend in about 30 mins.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Behan »</TD></TR><TR><TD CLASS="quote">you could get the universal from autozone for $60.00 bucks. all you have to do is either cut and splice the wires and connect using the connector they supply or solder the wires (preferred). spending 60.00 extra dollars for a connector is pretty retarded IMO. i installed one last weekend in about 30 mins. </TD></TR></TABLE>
the universal is still $113 for a prelude from my autozone!
so you get the connector though?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killa_lude »</TD></TR><TR><TD CLASS="quote">
so you get the connector though?</TD></TR></TABLE>
then your autozone is trying to screw you. i just bought one last week for 60 or so bucks. it was a bosch universal 4 wire. maybe you could try ordering online, the link 4bidden provided has universals listed for 59.99. Or you could try autozone.com.
yes they come with a connector but i soldered the connections and used heat shrink on the wires.
edit: direct link - http://www.autozone.com/servle...ENSOR
i guess it was 70.00 bucks but there you go.
