do new hondas come with overfilled engine/tranny?
Old Apr 1, 2004 | 07:52 PM
hellas's Avatar
Default do new hondas come with overfilled engine/tranny?
the parents just picked up a crv and both the engine and tranny(a/t) are overfilled quite a bit
is this normal? i dont feel good about removing drain plugs on a car with 7 miles
Old Apr 1, 2004 | 08:20 PM
95hatch's Avatar
Default Re: do new hondas come with overfilled engine/tranny? (hellas)
did you check it with the car running, and im not sure if you need it in park or nuetral? i have never had experience with it but i am sure it could effect the readings.
Old Apr 1, 2004 | 09:18 PM
blueeg's Avatar
Default Re: do new hondas come with overfilled engine/tranny? (95hatch)
should be at the top dot on the dipstick when its warm.
Old Apr 1, 2004 | 09:25 PM
hondatim's Avatar
Honda automatic transmissions are checked with trans in park and engine not running. level should not be any higher that top of hash mark on dipstick.
Hope this helps...
Old Apr 1, 2004 | 09:59 PM
mphilly09's Avatar
you shouldn't have anything overfilled from the manufacturer the car should be running when you check the trans fluid try that and see if it stays the same
Old Apr 2, 2004 | 05:15 AM
JimBlake's Avatar
Default Re: do new hondas come with overfilled engine/tranny? (mphilly09)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mphilly09 &raquo;</TD></TR><TR><TD CLASS="quote">you shouldn't have anything overfilled from the manufacturer the car should be running when you check the trans fluid try that and see if it stays the same</TD></TR></TABLE>The engine should be running or not running ACCORDING TO THE OWNERS MANUAL. Most cars you leave them running; but for some reason most hondas you get it warmed up & turn it off. But they ALL tell you which way to do it in the book.
stevescivic
Feb 28, 2007 03:44 PM
AnAccordIsForever
Nov 22, 2005 03:55 AM
AnAccordIsForever
Oct 14, 2005 01:28 PM
GdmLaz
21
Mar 10, 2005 12:50 PM
C_H_A_D
Oct 11, 2004 09:44 PM
