h22 to h23 tensioner question
Old Apr 1, 2004 | 06:24 PM
thehondaguru's Avatar
Default h22 to h23 tensioner question
I noticed in my helms manuel that there is a a bracket that is shown behind the tensioner pulley and a blot going through the hook on the left side of the tensioner to hold it in place.
I was wondering if it is even a nesessity because it isnt shown in the how to by 2point6.
If it is not then I am not going to worry about it. It seams that it has a mojor role in the tensioner process but it isnt shown in 2point6's how to so I am curious.
Old Apr 1, 2004 | 06:34 PM
4bidden's Avatar
Default Re: h22 to h23 tensioner question (95 lude)
It locks the timing belt tension for when you loosen the adjustment bolt again to tension the balance shaft belt. You remove the bolt that goes through the bracket before you put the timing covers back on.
To put it simply, its not necessary, but can simplify things.
Old Apr 2, 2004 | 02:20 AM
Default Re: h22 to h23 tensioner question (4bidden)
Sweet thanks!
Old Apr 2, 2004 | 06:12 AM
LudeyKrus's Avatar
Which bolt is it you're talking about?
I remember there were one or two bolts I removed b/c they weren't necessary anymore when I did my conversion.
Old Apr 6, 2004 | 06:02 AM
93H22ACX's Avatar
dont forget to use the H22 oil pump.
Old Apr 6, 2004 | 06:50 AM
prelittlelude's Avatar
Default Re: h22 to h23 tensioner question (95PRELUDEVTEC206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95PRELUDEVTEC206 &raquo;</TD></TR><TR><TD CLASS="quote">dont forget to use the H22 oil pump. </TD></TR></TABLE>
i just checked the part numbers, the h22 and h23 oil pump are the same., atleast http://www.slhondaparts.com says so
Old Apr 6, 2004 | 07:15 AM
Daemione's Avatar
It's just one of the bolts for the timing belt cover. Like 4bidden said, you use it temporarily to hold tension on the timing belt while you adjust tension on the balancer belt. The Helms outlines the process.
Yeah, this makes no sense . . . the oil pump has nothing to do with it.
Old Apr 6, 2004 | 07:19 AM
93H22ACX's Avatar
Default Re: h22 to h23 tensioner question (prelittlelude)
cool
JDMGTI
Sep 5, 2008 04:35 PM
h22sedan
Nov 8, 2006 05:20 PM
h8trix
Aug 11, 2005 08:36 AM
slomofo
Feb 28, 2003 07:17 PM
Mikey3000
Jan 24, 2002 12:15 PM
