Obd1 Codes
Old Apr 1, 2004 | 05:35 PM
HamiltonRex's Avatar
Default Obd1 Codes
Today my buddy came over and hes wanted to hear what my exhaust sounded like.
Anyways it was very damp out and the motor was cold, it was a bit above freezing, and i reved my cold engine to 6k, when i let off it dropped down bogged then died.
After 2 minutes of sitting it runs fine but im getting a code.
Its a obd1 P28 Ecu, it goes blink......blink......blink..blink. 2 long blinks then 2 short ones.
Anyone know what this means so i can fix whatever it is?
Thanks alot!
-Eric
Old Apr 1, 2004 | 05:44 PM
mmuller's Avatar
Mad Scientist
Default Re: Obd1 Codes (HamiltonRex)
code 22:Vtec oil pressure switch
Old Apr 1, 2004 | 05:58 PM
Default Re: Obd1 Codes (mmuller)
i was searching a i kinda found out that it could be 2 codes, a code20 and a code2, is this true?
and why would my vtec thing f-up? hmm.. time to re-set the Ecu.
-Eric
Old Apr 1, 2004 | 06:00 PM
kreush33's Avatar
cause you reved it past vtec when it was cold
Old Apr 1, 2004 | 06:12 PM
Default Re: Obd1 Codes (kreush33)
mehh, have before.
Reset the ecu solved the problem
-Eric
HamiltonRex
May 3, 2011 04:08 PM
nus_dogg
Oct 30, 2010 09:40 AM
B18 CYA
Jun 25, 2004 01:44 AM
