obd1 codes
Today my buddy came over and hes wanted to hear what my exhaust sounded like.
Anyways it was very damp out and the motor was cold, it was a bit above freezing, and i reved my cold engine to 6k, when i let off it dropped down bogged then died.
After 2 minutes of sitting it runs fine but im getting a code.
Its a obd1 P28 Ecu, it goes blink......blink......blink..blink. 2 long blinks then 2 short ones.
Anyone know what this means so i can fix whatever it is?
Thanks alot!
-Eric
Thanks alot!
-Eric
first i would try and reset the ecu and see if you still get that code
variable vavle timing and valve lift electronic control pressure switch( vtec pressure switch)
i have a obd1 h22a p13 ecu and i swap the h22a obd1 in my 1992 honda accord ex wagon what wire do i have to conect to hook up the vtek is it the vtek solenoid and the knock senssor duzz eny one know what i need to do
