92-95 civic charge pipes
Just wondering which mandrel bent piping would I need from this website for my charge pipes on my t3 sohc turbo setup?
http://www.speedpartsrus.com/
click on catalog, than mandrel piping
thank alot for your help
check out this site: http://www.cse.uconn.edu/~yele....html
I followed his directions with the jc whitney piping and it worked out perfectly. I should have the pipes back welded by monday. I'll post up some pics once i get everything painted and such
hey man, i just did the pipes on my 95 coupe. i went with summit. that site you have doesnt 2.25 which is closest to your tb and prolly what the size of you ic is.
http://www.summitracing.com
http://store.summitracing.com/...=ecat
summit has pipes too and i think they are a little cheaper than the hooker ones above. either way i used them and they worked great.
i did my pipes like integras and didnt come through the airbox hole, i had it like that before i and didnt really like it, its just as easy to go around and back up
i used like 3 90's and 2 180s all 2.25
and used 2 90's for the downpipe.
i suggest getting like 3-4 90's and atleast two 180s cause you gonna screw up atleast one piece
good luck
good luck
Here u go GreddySi
81ZX3031U 180 Degree Mandrel-Bent Aluminized Tubing <--u'll need 2of these http://www.jcwhitney.com/webap...10101
81ZX2953P 90 Degree Mandrel-Bent Aluminized Tubing
oxSLEEPERxo
Dec 29, 2004 05:31 PM
Erik_Pb_Foot
Jan 24, 2004 11:31 AM
