squeeky clutch pedal
Old Apr 1, 2004 | 04:13 PM
xdjoynerx's Avatar
Default squeeky clutch pedal
i have a g1 (cable) if that makes any difference. ive wd 40d the **** out of the return spring and both bushings and is still squeeks. it sounds like sprring, so after all was done and it still squeeked, i mollyd the spring and spring ends completly, and it still squeeked. so i cleaned up all the molly, and er wd40d every thing. still squeks. wtf
Old Apr 1, 2004 | 04:30 PM
1FastCoupe's Avatar
Default Re: squeeky clutch pedal (xdjoynerx)
its probably the throw out bearing in the tranny..if the shaft has not alot of grease on it, it will squeak when you press the cluth pedal...ive had it happen
Old Apr 1, 2004 | 04:40 PM
xdjoynerx's Avatar
it sounds like its coming from that area though......... not the tranny
Old Apr 1, 2004 | 06:03 PM
EG6[B16A1]'s Avatar
Default Re: (xdjoynerx)
yeah? my clucth pedal does that too, my one buddy told me its my spring I need to replace. I haven't looked into it. Maybe this would help
Old Apr 1, 2004 | 06:17 PM
b18c_power's Avatar
Have you checked the master cylinder?
Old Apr 1, 2004 | 06:19 PM
b18c_power's Avatar
Default Re: squeeky clutch pedal (b18c_power)
You can also try replacing the oil with some new fluids for the clutch but if that still doesn't help then you may want to lubricate the master cylinder.
Old Apr 1, 2004 | 08:38 PM
xdjoynerx's Avatar
i have a cable clutch.
im guessing now thogh if the grese wont do it, im just gonna replace the spring
AndyD
Sep 4, 2020 09:37 PM
brianpdx96accor
Transmission & Drivetrain
May 22, 2014 02:31 PM
chikin pickle
Dec 16, 2010 06:47 PM
delsolb16
13
Oct 1, 2005 11:09 AM
