how to adjust hydro clutch pedal??
Old Apr 1, 2004 | 02:41 PM
crazy eyez killa
Guest
Posts: n/a
Default how to adjust hydro clutch pedal??
How do i adjust the clutch pedal in my 99 Civic Si?
Its floppy near the top, but id say it engages OK
probably nearly 2 inches of total flop at the top
Thanks
Old Apr 1, 2004 | 03:11 PM
greebler's Avatar
Default Re: how to adjust hydro clutch pedal?? (KURRRWA)
how many miles do you have on this engine/clutch? It could just be worn out, because you can't really adjust a hydro clutch pedal.
Old Apr 1, 2004 | 03:38 PM
doublejz's Avatar
Default Re: how to adjust hydro clutch pedal?? (greebler)
mine is the same way after i put an act clutch in, since the day it was installed it hasn't changed. There is a bolt coming out the the master clutch cylinder that goes through your clutch pedal with a nut on it. The more you extend the bolt outta the pedal the more travel your clutch will have, which will let you push your clutch pedal down further letting the clutch make more contact.. You probably wont get rid of all the soft pedal though.
Old Apr 1, 2004 | 04:03 PM
SAVIOVEGA's Avatar
Default Re: how to adjust hydro clutch pedal?? (doublejz)
You say its floppy at the top. What I did with my "floppy" pedal was adjust the switch on the clutch pedal. Its near the top of the pedal. Just loosen the lock nut and turn the switch in, then tighten the lock nut. Just look at the switch and you'll see what I mean.
Old Apr 2, 2004 | 10:44 AM
crazy eyez killa
Guest
Posts: n/a
Default Re: how to adjust hydro clutch pedal?? (SAVIOVEGA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SAVIOVEGA &raquo;</TD></TR><TR><TD CLASS="quote">You say its floppy at the top. What I did with my "floppy" pedal was adjust the switch on the clutch pedal. Its near the top of the pedal. Just loosen the lock nut and turn the switch in, then tighten the lock nut. Just look at the switch and you'll see what I mean. </TD></TR></TABLE>
Thank you saviovega
BTW everybody knows HBK Shawn Michaels would beat your ***
Sweet chin music
Old Apr 2, 2004 | 11:27 AM
SAVIOVEGA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KURRRWA &raquo;</TD></TR><TR><TD CLASS="quote">
Thank you saviovega
Sweet chin music
a1320addict
Jun 7, 2005 11:06 PM
94ls
Sep 29, 2004 08:17 AM
MrSmith
Sep 28, 2001 08:30 PM
