Noobie needs advice on launching GSR
Old Apr 1, 2004 | 12:18 PM
sp00led's Avatar
Default Noobie needs advice on launching GSR
Ok im heading back to the track sat. night. This will be my second time only and the first my all stock gsr ran a shitty 10.7(1/8mile) I need some help. I know this time im going to lower my tire pressure to 20lbs and mabey burn out in second for a few secs. What rpm should i drop at and how high should I run through each gear. If anyone has ANY good advice for a total drag noob then please post because I felt last time that mabey if I shifted differently I could have shaved some time. THanKs...
1999 Acura Integra GS-R 2dr
Modified by redeyz at 12:06 AM 4/2/2004
Old Apr 1, 2004 | 12:24 PM
SadisticRacing's Avatar
Default Re: Noobie needs advice on launching GSR (redeyz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redeyz &raquo;</TD></TR><TR><TD CLASS="quote">my all stock gsr ran a shitty 10.7(1/4mile)</TD></TR></TABLE>
There's no way you ran a 10.7 in the 1/4 mile with a stock GSR.
Old Apr 1, 2004 | 12:25 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
WOW 10.7 1/4 MILE I THINK THAT WAS A TYPEO ANYWAYS IF YOU ARE ON STREET TIRES DONT BOTHER BURNIN THEM ITS WORSE THEN NOT. IF YOU ARE ON STREET SLICKS OR SLICKS THEN BURN OUT IN 2ND GEAR. THE REASON FOR THIS IS YOU GET THE TIRES SPINNING FASTER THAN 1ST. ALSO ON A STOCK GSR I PERSONALLY WOULD SHIFT AT 7900.. LAUNCH MAYBE AROUND 3500-4000 AND FEATHER THE GAS UNTILL IT HOOKS
Old Apr 1, 2004 | 12:30 PM
Default Re: Noobie needs advice on launching GSR (HOOKUPS)
Yeah I figured it was a typo but yeah my wife launches hers at 4000 rpm and shifts at 7900-8000 and pulls 15.2's all day long.
Old Apr 1, 2004 | 02:02 PM
Jokerluv's Avatar
10.7 in the 1/8th maybe
Old Apr 1, 2004 | 02:11 PM
moyo_rican's Avatar
DONT DRAG RACE JUST PUT A NICE BODY KIT ON IT AND SOME NICE ALTEZZA LIGHTS.
Old Apr 1, 2004 | 03:06 PM
sp00led's Avatar
lol major typo i mean't 1/8
Old Apr 1, 2004 | 03:08 PM
sp00led's Avatar
Default Re: (redeyz)
R/T .497
60' 2.583
330 7.141
1/8 10.762
MPH 68.52
Old Apr 1, 2004 | 04:06 PM
h22avid's Avatar
That R/T is way better than my first time out
My first time out I had...
R/T 1.083
60" 2.209
330 6.033
1/8 9.160
MPH 79.00
1000 11.869
1/4 14.267
MPH 92.26
This was a really shitty run though... I let off the gas way too early and coasted through the end
So yeah, I need help in this department too. I have a H22 EJ1 so I should be making much better times. I figured I have at least a 13 second car but a 14 second driver
Old Apr 1, 2004 | 04:24 PM
crazzy's back's Avatar
just put some bf's on it and launch at 7000prm and shift at 8100..
i went 14.7@93 that way and a stock gs-r with just a intake if that even mattered..
Old Apr 1, 2004 | 04:31 PM
sp00led's Avatar
Default Re: (h22avid)
H22avid those times u posted what were u in and what mods?
Old Apr 2, 2004 | 03:01 AM
h22avid's Avatar
Pretty much bone stock as far as the motor is concerned.
I've got WS cat back, a really shitty Megan Racing header that is probably robbing me of power(only got it because my stock header was bent up pretty bad and this was $50 ), short ram intake, and ACT Heavy Duty Pressure Plate w/ Street Disc.
90efSI
May 13, 2007 12:18 PM
team 15
Mar 26, 2007 11:40 AM
s0C@LDC
Apr 13, 2005 07:36 AM
MikeTV
May 21, 2003 04:38 AM
Ideal R
Oct 1, 2001 06:03 PM
