obd1 distributor (d15b7) on d15b2 in crx... no spark???
Old Apr 1, 2004 | 08:52 AM
dohcnotec's Avatar
Default obd1 distributor (d15b7) on d15b2 in crx... no spark???
Got a problem... I had a d16z6 (sohc vtec), in a crx w/ a obd1 dizzy, injectors & P28 ecu... ran perfectly... swapped in a d15b2 w/ a d15b7(obd1) distributor, obd1 injectors and P06 ecu... Only getting spark out of one wire... no other plugs are getting spark? is the b7 distributor compatible w/ the b2 head? bolts up perfect but no spark? Also, the distributor came off of a running car (last week).
Old Apr 1, 2004 | 01:00 PM
dohcnotec's Avatar
Default Re: obd1 distributor (d15b7) on d15b2 in crx... no spark??? (dohcnotec)
nevermind... it was the distributor... swapped in a y8 dist. i had and it fired right up... that's funny cus the b7 dizzy was running when i pulled it off... ???
Omegax10
Nov 27, 2012 10:59 PM
efjones9
Jan 15, 2009 10:17 PM
Sirex
Mar 18, 2003 07:31 PM
b16 matt
Feb 10, 2003 06:46 PM
