Kill switch?
Old Apr 1, 2004 | 07:47 AM
ORcivicsi's Avatar
Default Kill switch?
I searched.
Can i get a picture of the main relay on the car under the dash. Also could you point out which wire is the power wire for the fuel pump. Thanks in advance.
This will be on a 00 civic si.
Old Apr 1, 2004 | 11:33 AM
mike1114's Avatar
Default Re: Kill switch? (ORcivicsi)
Pull out back seat.
See metal cover, take off
There's a bunch of wires going into this cover, on the underneath side you will see two wires go off by themselves and connect to where the others don't these are the fuel pump wires. One is yellow/green that is power, other is negative. Cut yellow/green wire and run wires from each side to a switch somewhere.
Old Apr 2, 2004 | 01:02 PM
ORcivicsi's Avatar
Default Re: Kill switch? (mike1114)
That method is too easy for theives to wire back up. All they have to do is take off back seat. Cut the extension wires and wire the yellow and green back togther.
Old Apr 2, 2004 | 01:03 PM
ORcivicsi's Avatar
I want to have one of the wires wired up at the relay or another spot so it isnt as easy for them. Where specifically does to power wire to the fuel pump run? Is it down the drivers side.
all_motor
Feb 3, 2013 11:30 AM
DarkDragon
Jun 12, 2005 12:03 PM
FalkenSiR
Dec 2, 2004 01:40 PM
BME1986
10
May 31, 2004 10:05 AM
smokinvtecCRX18
Jun 15, 2003 01:31 PM
