swapping prelude brakes to a Eg
Old Apr 1, 2004 | 07:39 AM
Boostage's Avatar
Default swapping prelude brakes to a Eg
my 94 coupe currently has braided ss lines. stoc ex front and GSR rear discs. if I were to change all four corners to 93 preludes, would my SS lines still work? I am assuming I need teh whole hub assembly from the lude. thanks
Old Apr 1, 2004 | 12:24 PM
Katman's Avatar
Default Re: swapping prelude brakes to a Eg (Boostage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">my 94 coupe currently has braided ss lines. stoc ex front and GSR rear discs. if I were to change all four corners to 93 preludes, would my SS lines still work? I am assuming I need teh whole hub assembly from the lude. thanks</TD></TR></TABLE>
I haven't heard of anyone trying to adapt the full blown Prelude rear brake system onto any civic - as in fitting the complete rear prelude trailing arm etc. I don't think it will work, the prelude rear trailing arm's geometry is more than likely, totally different in spec than a civic's rear trailing arm system. I could be wrong though, as I've personally never tried this though.
You do have other options though if you'd like to achieve a prelude sized (11") brake system on your EX. I dunno if you know, but Fastbrakes sells a mounting kit + custom rotors (prelude sized) for this specific scenerio.
Here's a few links to their products...
Their 11" front rotor dubbed "SpecR Rotor" made for 4x100 lug pattern:
http://www53.ssldomain.com/fas...SpecR
(you use this rotor in conjunction with an actual prelude caliper which bolts right up to your EX knuckle)
Their 11" front clalipers here:
http://www53.ssldomain.com/fas...R-cal
and their 11" rear brake kit here:
http://www53.ssldomain.com/fas...ear11
hit up Brian (owner of Fastbrakes) if you have any further questions about his kits.
Old Apr 3, 2004 | 02:07 AM
D16Z6racing's Avatar
Default Re: swapping prelude brakes to a Eg (Katman)
Never heard of using Prelude rear brakes on a Civic.
I've seen Prelude front brakes on a 94 Civic DX coupe done before.
Old Nov 14, 2006 | 06:26 PM
repn a lude's Avatar
Default Re: swapping prelude brakes to a Eg (D16Z6racing)
im gonna try and put my 4th gen prelude brakes front and rear on my ek im researching.
kbud
Aug 3, 2007 08:45 AM
foodmart
May 28, 2006 02:27 PM
Boostage
Apr 1, 2004 02:07 PM
91ED7Si
Aug 2, 2003 12:26 PM
