blueish black smoke
we need more info. stock ecu? stock injectors? what mods to u have?
you need to find out what the problem is first before you can fix it. running rich and burning oil are two TOTALLY different things. as far as I know, blue/black smoke is usually an indication of oil burning and not running rich. If you are running rich then obviously we need more info on the set up and you need to lean it out with some kind of tuning device or smaller injectors. if you are burning oil, check your plugs and they will be shot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC »</TD></TR><TR><TD CLASS="quote">how cna i go about fixing this problem</TD></TR></TABLE>
first off, stop using mobil 1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">
first off, stop using mobil 1</TD></TR></TABLE>
I used to use M1. Then used Schaeffers all last year. Now I'm back on M1.
You know what? It all burns the same. 10w-30, 15w-40, 5w30.... all the same. Maybe a few oils burn less... but I've tried 4 brands - its all the same on the track - below 75F nothing happens. Above - lots of burning.
Our engines run hot, and when the out side air temp (or track temp) is above a certain level, we will burn oil. Some more than others.
I burn VERY little oil when the outside air temp is below 75F. I burn progressively more oil (on the track only) as the outside air temp goes up above 75F.
We all need oil temp gauges and oil coolers.
first off-how many miles do you have on the car?
is the smoke only during the mornings? ona cold day? is there this color smoke when you are accelerating? or when you are decelerating? or at idle? how is it blueish black smoke?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC »</TD></TR><TR><TD CLASS="quote">motor has about 35k on it, it smokes only at WOT esp vtec, and isnt just a day or night thing</TD></TR></TABLE>
Motor is practically new with only 35k miles on it. Black smoke? If so you're running rich..
yeh, i mean i know c5 motors are notorious motors are notorious for burning oil. i burn about 1-1.5 quarts between every 3k miles
well the smokes seems to be more black to me, at the track the other day my buddy said it was kinda blueish so i dunno
I used mobil 1 synthetic for two months.......burned oil all the ******* time, A quart is like 5 bux too. Then I switched back to my Castrol GTX 5w-30.......and like the bottle says "drive hard", because it dont burn a drop..
robbys89
Aug 25, 2009 07:09 AM
Blazin Si
19
Jun 26, 2005 08:59 AM
Grip
Aug 5, 2004 02:22 PM
