Which harness should I use??
Old Mar 31, 2004 | 11:47 PM
jisu009's Avatar
Default Which harness should I use??
OBD-0 to OBD-1
Swapping in a D16Z6 in a 1991 CRX. Do I keep the engine harness from the D16Z6 on, or do I swap on the D16A6 engine harness?
So i have the P28...
The Chassis harness (that ends in the plugs by the fuse box on the left shock tower) is obd-0.
The engine harness that came on the D16Z6 (OBD-1) has square pulg that would plug into the chassis harness, if the chassis harnees was OBD-1....which it is not.
So do I use the engine harness off of the D16a6, which has the proper (round style) plugs?
Or do I use the D16Z6 engine harness with the square plugs and pull the plugs off the D16a6 harness and re-pin them onto the D16Z6 engine harness??
Thanks guys!
Old Mar 31, 2004 | 11:48 PM
jisu009's Avatar
Default Re: Which harness should I use?? (jisu009)
BTW
I am swapping this for a friend and on a pretty tight timeframe
Old Apr 1, 2004 | 01:58 AM
Fobtions's Avatar
use the original d16a6 engine harness.
Old Apr 1, 2004 | 03:17 AM
1st-hybrid's Avatar
Default Re: Which harness should I use?? (Fobtions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">use the original d16a6 engine harness.
This is correct use the harness that came on the original engine, then convert to obd1
Old Apr 1, 2004 | 07:43 AM
jisu009's Avatar
Default Re: Which harness should I use?? (1st-hybrid)
Bingo! Thanks guys!
Valo
May 28, 2010 09:54 PM
daredeezy619
Nov 21, 2008 04:38 PM
bluelsvtecda9
Jan 27, 2007 03:17 PM
ekslax
11
Aug 30, 2006 02:51 PM
stevomc51284
May 3, 2005 04:42 AM
