JDM ITR cluster install temp goes to hot?
Old Mar 31, 2004 | 09:54 PM
01DC-2's Avatar
Default JDM ITR cluster install temp goes to hot?
wats up guys.. i need some help here.. i just put on a 2000 JDM ITR cluster, and the damm needle on the temp moves quickly to HOT and just stays there, even after the car is warmed up..??
as for the fuel gauge i filled my tank up and it jumped way passed the FULL line??
by the way its on a 2001 gsr..
any info is greatly appreciated
Old Mar 31, 2004 | 10:50 PM
01DC-2's Avatar
Default Re: JDM ITR cluster install temp goes to hot? (01DC-2)
bump for the night.. hopefully someone can help me out b4 i go to work in the morning..
Old Mar 31, 2004 | 11:27 PM
B2FiNiTY's Avatar
You need to swap the green motherboard on the back OR swap the gauges.
USDM green motherboard onto jdm cluster
OR
JDM gauges swapped into the usdm cluster.
Both will correct your problem.
Old Apr 1, 2004 | 05:21 AM
threatcon13's Avatar
New User
I used to have a 98 jdm itr cluster in my 01 gsr, just switch the green films in the back like b2finity said. It works fine.
Old Apr 1, 2004 | 09:43 AM
01DC-2's Avatar
thanks guys... works just fine now
GdmLaz
Jan 3, 2012 07:46 PM
kenji
Aug 11, 2005 11:09 AM
shoei
Sep 23, 2004 08:17 PM
SMZ GSR
May 10, 2004 02:57 AM
JjuuN R
Jan 9, 2004 04:32 PM
