How hard is it to claibrate gauges?
Old Mar 31, 2004 | 06:57 PM
curt2121's Avatar
Default How hard is it to claibrate gauges?
With so many people that have white face or some aftermarket gauge faces, I'm guessing it can't be too hard, but how is it done? I'm wanting to put some gauges in my del sol but I want to make sure they are calibrated correctly. Thanks for the help
Old Mar 31, 2004 | 10:59 PM
TeamCracka's Avatar
Default Re: How hard is it to claibrate gauges? (curt2121)
You dont mess with the needles. The white face/indiglo whatevers slide on so theres no calibrating involved.
Old Apr 1, 2004 | 12:21 AM
igor's Avatar
If you go to a Dyno you can get a speed reading done to see if your speedo is out (ie Indicated speed vs actual speed).
Calibrating something as coomplex as a speedo would, in all probablity, be a real **** of a job. Unless you had all the equipment, and knew exactly what you were doing.
mpxs20
Oct 30, 2005 07:22 PM
solman
Jan 25, 2003 06:00 PM
JumbosGS-R
Oct 17, 2001 10:29 AM
