Are 7/8 in. diameter sway bars overkill?
Old Mar 31, 2004 | 06:08 PM
jtl's Avatar
jtl
Default Are 7/8 in. diameter sway bars overkill?
I see kits for front and rear 7/8 in. sway bars. Usually the front bar is thicker than the back. maybe it's different for crx's because of the short wheel base. Anyone have input on this? thanks.
-Jake
Old Mar 31, 2004 | 06:18 PM
regime's Avatar
Default Re: Are 7/8 in. diameter sway bars overkill? (jtl)
stronger front will cause oversteer
a stronger rear will cause understeer.
if im thinking of it right. i always mix them up
size wise im not sure what you should go with
Old Mar 31, 2004 | 06:19 PM
goforbroke's Avatar
MEAT PATTY
I rear bar is usually thicker then the back. You need more rotation thats why they have the thicker bar in the rear. If the bar is too thick in the front it will cause some understeer. 7/8=22mm thats not over kill at all. Most of the ones on the market for our car our 22mm. I think our stock one is like 13-14mm, not sure though.
Old Mar 31, 2004 | 06:30 PM
jtl's Avatar
jtl
Default Re: Are 7/8 in. diameter sway bars overkill? (goforbroke)
Thanks for the replys, but I'm wondering why they sell kits with both bars the same diameter. Usually for other cars the rear bar is thinner than the front.
Old Mar 31, 2004 | 06:34 PM
XrcR6's Avatar
Default Re: Are 7/8 in. diameter sway bars overkill? (regime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by regime &raquo;</TD></TR><TR><TD CLASS="quote">stronger front will cause oversteer
Backwards... all else being the same (location and # of bends in the bar, material, etc.) a thicker front sway bar will induce understeer/push. A thicker rear sway bar will induce oversteer/promote rotation.
Edit: This applies to FWD...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jtl &raquo;</TD></TR><TR><TD CLASS="quote">I see kits for front and rear 7/8 in. sway bars. Usually the front bar is thicker than the back. maybe it's different for crx's because of the short wheel base. Anyone have input on this? thanks.
Depends on the applicaton. As mentioned 7/8" = 22mm not unreasonable on the rear of a FWD Honda, but pretty much the standard for a CRX (although there are a couple semi-custom ones that go bigger). For competition purposes most people like stock front/big rear or no front/big rear. Depends on auto-x/track, driver preferences, rest of car setup, etc.
The typical aftermarket kit, while increasing performane (intended for street/sport driving), will utimately err on the side of safety (neutral to mild understeer at the limit). They usually sell matched bars since they can't trust the drivers skill to be up to the increased rotational characteristics the back end will have when you get off the throttle (panic lift/typical street driver tactic). Even an experienced driver may get into trouble given adverse road or weather conditions, which the sway bar manufacturer can't control (outside of putting that blanket "These are competition parts never to be used on public highways..." disclaimer that everyone ignores...)
Midori Green
Jun 21, 2008 01:04 AM
Ti3d in
Suspension & Brakes
17
Feb 8, 2005 07:37 AM
PreludePhill
Jan 10, 2005 04:22 AM
p1driftfiend
14
Feb 23, 2004 12:18 PM
Supermako
Jun 30, 2003 09:52 PM
