brake question: Does the capiler rest on the brakes?
Old Mar 31, 2004 | 06:04 PM
Sinner's Avatar
Default brake question: Does the capiler rest on the brakes?
Heres the deal, I got a rear disc swap, but it came disassmbled. I have out my hynes manual and the picture gives me the impression that the capilers's pads actually rest on the brakes... seems like that would use up the brakes fast. Is this correct? probably not, I just want to know.
Nick
Old Mar 31, 2004 | 06:15 PM
Sliced Beard's Avatar
Default Re: brake question: Does the capiler rest on the brakes? (Sinner)
the pads on disk brakes will always be in contact with the disk
pads do not "retract" they just clamp and when the caliper relases the pressure they just sit wherever the rotor pushes them to
hence the rubbing sound when you spin you wheel when your car is off of the ground
it is normal and it only causes minimal wear that you would never notice unless your caliper is not releasing pressure like it should
snobordin8
Suspension & Brakes
Nov 22, 2008 08:06 PM
98TegLS110
Aug 19, 2007 03:25 PM
splink
Aug 21, 2004 06:49 PM
Poopie
Jun 25, 2004 07:03 PM
valentinecr
May 3, 2004 05:35 AM
