wiring problems
Old Mar 31, 2004 | 05:28 PM
Cornwhiskey's Avatar
Default 89 civic automatic dpfi to mpfi help please
My friend switched his 89 automatic 4 door civic from dpfi to mpfi he used a d16z6 head and he bought the ps9 computer because it being automatic. it is flashing code 20 witch is electronic load dector or something well if u turn the car off the code still flashes and the battery light and oil light are staying on what is the prob is the wiring or what????
Modified by onefastcrx88 at 2:45 AM 4/1/2004
Modified by onefastcrx88 at 3:18 PM 4/1/2004
Old Mar 31, 2004 | 06:07 PM
benn2k's Avatar
bump
Old Mar 31, 2004 | 06:19 PM
onefaazztcrx's Avatar
Default Re: wiring problems (onefastcrx88)
anyone who can help with this id appreciate it
Modified by onefaazztcrx at 3:30 AM 4/1/2004
Old Mar 31, 2004 | 06:30 PM
Default Re: wiring problems (onefaazztcrx)
nobody
Old Mar 31, 2004 | 08:59 PM
comeon guys some help would be great here thanks
Old Apr 1, 2004 | 06:15 AM
bump
Old Apr 1, 2004 | 09:15 AM
civickiller's Avatar
for a code 20
with the ignition off, open the main fuse box, the one in the engine bay. now pull out the 3 wire connector, it should have a blk, blk/yel, and a grn/red.
turn the ignition switch on and test for battery volts between the blk and blk/yel wires. there should be battery volt.
go do that and let me know the results
Cornwhiskey
Apr 1, 2004 06:15 AM
-KangaRod-
Oct 18, 2003 10:00 PM
type Gendy
Aug 2, 2003 05:44 PM
