The head is on....
Old Oct 24, 2001 | 01:36 PM
MrDX's Avatar
Default The head is on....
Well, the P&P'd D15B7 head is on... It also has a ported t/b, GUDE street cam, 5angle valve job, and cam gear. Once my break-in mileage period is over.. I'll have it dyno tuned and post up some numbers and video. I'm still waiting for my ECU to take advantage of the cams ability, but for now... there is a nice bump at 3500rpm... I don't want to rev it too high until the valves settle in. But it does sound like a Prelude on steroids.
Old Oct 24, 2001 | 01:37 PM
DragII's Avatar
25 Year Member
Default Re: The head is on.... (MrDX)
you have done more to that engine than anyone I know....let us know when you dyno it...I'm dying to know what it puts out.
Old Oct 24, 2001 | 01:43 PM
MrDX's Avatar
Default Re: The head is on.... (DragIIcivic)
I just like trying stuff that most people won't do... I'm really wanting to see what the dyno graph curves shows.
Old Oct 24, 2001 | 05:33 PM
willyboyK20's Avatar
hey where did you get the job done. I was thinking about going the same route with my ex. That's going to be a serious sleeper. Also how much did the gude cam cost
Old Oct 24, 2001 | 06:00 PM
MrDX's Avatar
Default Re: The head is on.... (willyboyD16)
I had it done at South Florida Performance for $800... Stage 3 P&P, 5angle valve job, new valves, retainers and locks. The GUDE cam ran me $260 from ARD performance, but GUDE I think is having a birthday sale, and they knocked off about $80-$100 on their products.
Old Oct 24, 2001 | 08:50 PM
MRXMUFFIN's Avatar
Did you get their ECU too. i got Gudes head and cams in my LS teg and was wondering about their ECU.
Old Oct 25, 2001 | 02:07 AM
MrDX's Avatar
Default Re: The head is on.... (MRXMUFFIN)
I have a spare ECU coming, once it gets in... I can send that one in as a core. I will get the ECU as well.
Old Oct 25, 2001 | 03:22 AM
Mista Bone's Avatar
D Tranny Guru
Dyno it..........
if you get 118 whp/135 crank hp or less, I can tell you how to do it cheaper.
Just I/H/E and a CRX Si cam.
Wait for the long rod version and 8500 rpm limit. Notice I was still making power when 6800 rpm limiter kicked it. Might have got 120 on a good day
Old Oct 25, 2001 | 03:58 AM
sohc_boy's Avatar
Default Re: The head is on.... (Mista Bone)
finally d-series tuners!!!!!!!!!!!!
Old Oct 25, 2001 | 04:13 AM
MrDX's Avatar
Default Re: The head is on.... (sohc_boy)
Everything looked reall promising since I bought the car 3yrs ago... with I/H/E combo, it got me 101.1 hp and 95.2 ft lbs also making power til the rev limiter kicked in... The CRX si cam is a great idea... I've read about it getting done in a book that I have, but since the head was ported, I needed a funkier lobe on the cam to get it to breath right as the rpm's go up. I'm just happy that it's on... I do notice a little bit of lag below 2500rpm but it's nothing that concerns me since I do 4000rpm launches off the line at the track.
Old Oct 25, 2001 | 05:15 AM
hvtec93's Avatar
New User
i have been playing with my d series for a while too its coming out nicecely but still a lot more to come
here is the list so far
eagle rods,
arias 10.5.1 compression
mugen chiped ecu,
clutch master stage 3 clutch
Kaaz LSD
short sfiter
VAFC
RC 270cc injectors
aem fuel rail
GSR pump
webcam or zex cam is coming plus tougher valvle spring
focuz tubular intake manifolf with short runners
plus all the regular bs, like aem cold air full exhaust, pulleys
msd 6al
msd blaster 2 coil
denso iridium plugs
magnecor wires
adjustable cam gear
suspension:
ebaich pro kit
agx 4 way shocks
bushings kit
camber kit front
toe adjust kit on the back
front 25mm sway bar, rear 22mm sway bar
front strut bar, rear struat bar
z10 traction control bar
rota slip stream rims
i think thats it i havent missed anything, i am not listing all the the extirior and inside mods
[Modified by hvtec93, 6:19 AM 10/25/2001]
Old Oct 25, 2001 | 05:56 AM
MrDX's Avatar
Default Re: The head is on.... (hvtec93)
Just a hint for those doing the D-series build-ups.... the valve springs are good for revs upto 8400rpm... If you go with stiffer springs, you will get premature wear on a GUDE and factory cam due to the newer springs increase the lift pressure.
Old Oct 25, 2001 | 05:58 AM
hvtec93's Avatar
New User
thank you i did not know that
my ecu will allow me to rev to 8500 my soft rev limiter is set at 8000
and i shift at 6800 for now
Old Oct 25, 2001 | 11:41 AM
Todd00's Avatar
I said I don't want a title!
The power in the D series is there...I'm glad that someone is finally trying to get it out of those motors.
There is a guy locally who has a D16a6 that makes 135 at the wheels. He had a race motor builder build it for him. That thing pulls like a madman and will give my R a run for its money.
Old Oct 25, 2001 | 12:56 PM
hvtec93's Avatar
New User
Default Re: The head is on.... (Todd00)
if you do your things right D is very capable engine
Old Oct 25, 2001 | 01:35 PM
WAFFLES's Avatar
A couple of questions for my d series guys:
I have d15b7 I think(not sure if it's 7 or8)
anyways I am building an ls/vtec right now and I might change up later on down the road to my stock d15 but only turbo the **** out of it.
1. What kind of mildly reliable power can I produce with a built d15 and turbo?
2. How strong are the internals, stock
3. Is it really expensive to make a lot of power out of one?
I'm not really a d series person, but if I can build a mid-13 sec turbo d, then that would kick ***.
Old Oct 26, 2001 | 05:44 AM
hvtec93's Avatar
New User
Default Re: The head is on.... (WAFFLES)
you can build a mid 13 sec d non turbo, one of my boddies has that with 12.1 compression and all other goodies non vtec runs mid 13's
Old Oct 26, 2001 | 10:34 AM
90accord1's Avatar
damn i give you d series guys mad props for doing that. i just took the easy route and stuffed the b16 in the civic hatch
Old Oct 26, 2001 | 11:10 AM
Chugger's Avatar
Default Re: The head is on.... (90accord1)
i've got a gude tb and a gude 96-99 sohc vtec cam coming the 96-99 cams are more aggresive than the ones for the 92-95 then maybe a 98 d-series head for higher compression well damn im tellin all my secrets shhhhhhhhhhh
lata
chris
Old Oct 27, 2001 | 12:39 AM
gubo22's Avatar
New User
Somebody please tell me if they have any 96+ D series with more **** than this:
99 D16Y8
Full port n polish
Balanced
titanium springs and retainers
gude modified cam
OBD1 mugen P28
10.5:1 SRP pistons over bore
Skunk2 cam gear
AEM CAI w/blitz filter
ACT extreme clutch
lightened fly wheel
Port matched intake manifold
O.B. Throttle Body
Apex VAFC
cusco oil catch can
msd wires w/ngk r plugs
ordered:
quaife lsd
z10 radius arms
comptech rear sway bar
msd ignition
Deciding on:
4.7 final gear
Everything in a 2000 hatch with custom paint and body kit
Old Oct 27, 2001 | 02:07 AM
mr2's Avatar
mr2
Default Re: The head is on.... (gubo22)
lol goo djob.. got pics?
Old Oct 27, 2001 | 09:34 AM
Total Eclipse's Avatar
New User
Default Re: The head is on.... (white eg)
Alright........im interested in doing a SOHC swap into a hatch possibly.........so what about stroking the motor? I know that Bisi has one in his 11 second all motor car.....i'd imagine that the streetable version of that motor would run pretty well......anyone doing/done/heard of this?
Old Oct 28, 2001 | 11:50 AM
MrDX's Avatar
Well...
D15B7
Stage 3 port and polish w/ 5angle valve job
Titanium valves, retainers, and locks
stock compression
GUDE street cam (2522)
GUDE ecu
OBX cam gear
K&N drop in with factory cold air intake system
ACT clutch
ACT lightend flywheel
ProFlowDesign 58mm ported t/b
Moroso wires/ngk plugs
On wish list for X-mas:
Matrix Motorsports GSR distributor
Quaife LSD
Z10 radius arm
Eibach sway bars
Apex'i turbo kit
Old Oct 28, 2001 | 01:18 PM
Halive's Avatar
New User
gubo do you have 1/4 times for you car?
Old Oct 28, 2001 | 04:10 PM
gubo22's Avatar
New User
Default Re: The head is on.... (Halive)
no 1/4 mile yet but with just ihe on the cx motor i got 15.85
going to dyno on nov 10, will post up a video of hopefully a 140+hp run
