Tranny/Clutch problem - need help diagnosing.
Old Mar 31, 2004 | 04:15 PM
631 Teggy's Avatar
Default Tranny/Clutch problem - need help diagnosing.
Modified by 631 Teggy at 9:37 AM 9/20/2005
Old Apr 1, 2004 | 04:53 AM
JimBlake's Avatar
Default Re: Tranny/Clutch problem - need help diagnosing. (631 Teggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 631 Teggy &raquo;</TD></TR><TR><TD CLASS="quote">B) The clutch pedal is out of wack, and it's not disengaging the clutch properly, which causes the grinding...</TD></TR></TABLE>This is so much easier to check, because all you have to do is stick your head down there & watch the action of the pedal. Look for pivot pins that are messed up. Holes for those pins that are worn into egg-shaped. Worn holes in the clevis at the end of the MC piston rod, where it attaches to the pedal. That's all simple mechanical stuff you can inspect right now.
Don't get me wrong - there's a good chance your clutch is actually messed up. But first you want to hope for the easy fix.
Old Apr 3, 2004 | 11:53 AM
631 Teggy's Avatar
Default Re: Tranny/Clutch problem - need help diagnosing. (JimBlake)
LoL
Old Apr 4, 2004 | 06:10 PM
yellow_jacket's Avatar
If the pressure plate is not fully releasing it will cause grinds or a hard time putting it into gear. If the fluid in the resevoir is clean and the master isn't leaking you more than likely have to pull the tranny and replace the clutch
Old Apr 5, 2004 | 04:15 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 631 Teggy &raquo;</TD></TR><TR><TD CLASS="quote">... Would a bad clutch lead to hard shifting as well? Or would that have more to do with the syncro's (have to jam it into gear sometimes)...</TD></TR></TABLE>Yes it'll cause hard shifting. Basically the clutch doesn't disengage all the way when you press the pedal down. If it's the clutch it'll happen in all gears, not just one. It's real unlikely that all 5 of your synchros go bad the same way at the same time.
Old Apr 5, 2004 | 04:36 AM
EF'n's Avatar
i have heard that the factory honda clutch disc springs can start to come out of their spots. if this starts to happen it/they will rub on either the pp or the flywheel. just wanted to throw this idea out there too.
Old Apr 5, 2004 | 08:13 AM
Tip of the sword's Avatar
also if your pressure plate is not dissengaging all the way it may be that your slave cylinder which is what controls the pressure plate pressure is going out. Not to commom on lower mileage transmission, but not entirely out of the question
Old Apr 6, 2004 | 10:09 AM
631 Teggy's Avatar
Default Re: Tranny/Clutch problem - need help diagnosing. (Tip of the sword)
Very good information Thanx guys... I'll be getting a new clutch very soon. I'll post back with results... Thanx!
Old Apr 10, 2004 | 07:09 PM
delsolsir2's Avatar
you wont know til you have it apart but i would almost be willing to bet my h22a delsol that your throwout bearing has a broken ear where it attaches to the clutch fork !!! will cause all your symptoms . all of them, your syncros are fine but dont keep driving it like that unless you want to pay for a tranny too. if you live locally i will do the clutch job for you. might as well spring for the whole clutch kit since you have it apart and since it sounds like you have been beating the ***** off of it
Old Apr 10, 2004 | 08:24 PM
Sliced Beard's Avatar
Default Re: Tranny/Clutch problem - need help diagnosing. (delsolsir2)
you might also want to check your release fork
(the part that pivots between the slave cyl and the TOB)
Old Apr 10, 2004 | 10:19 PM
631 Teggy's Avatar
Default Re: Tranny/Clutch problem - need help diagnosing. (dirtyd463)
I'll check it all. I just bought An Act clutch kit: #AI4-HDSS, and Got me a Spoon flywheel while I was at it.
I really think it's the throwout bearing though. Thats why it clicks at idle when I kick in the clutch... And yeah - I stopped driving the car temporarily.
Old Apr 15, 2004 | 03:55 PM
transmission11's Avatar
you would buy a spoon flywheel..hehe j/k. Your teg is getting pretty dope bro.
Old Apr 15, 2004 | 05:29 PM
631 Teggy's Avatar
Default Re: Tranny/Clutch problem - need help diagnosing. (transmission11)
I ordered my **** from Modacar... They were out of the spoon flywheel, so I got the Cusco flywheel instead... Thanx Matt..
CraiGlOl
Jul 9, 2009 07:52 AM
.I.Need.Money.
Aug 16, 2008 04:03 PM
popo bawa
Jul 17, 2006 09:57 AM
ZeroGSR
Oct 1, 2004 01:49 PM
monsterb18b
Nov 20, 2003 09:45 AM
