i need to connect meter wire
Old Mar 31, 2004 | 03:59 PM
BlUsUnSGSR's Avatar
Default i need to connect meter wire
yea i have a line for a air fuel meter and i dont know where to connect it?
Old Mar 31, 2004 | 04:04 PM
3.504's Avatar
Default Re: i need to connect meter wire (BlUsUnSGSR)
what year car?.... and which computer? heres a little guide for obd 1 stuff..... slot d14 on the ecu.... pin the info wire from the a/f guage into this slot.... the slots (pins) on the ecu are set up like this for obd1: three harness plugs from left to right (a) is the first (b) is the second and (d) is the third. each clip is double stacked and rowed accross the way the numbers count are odds on top row evens on bottom row. i hope that helps you out
if its an obd2 car...... screw you, i dont feel like looking up the pinout and wire diagram
Old Mar 31, 2004 | 05:29 PM
BlUsUnSGSR's Avatar
Default Re: i need to connect meter wire (3.504)
thanks for that and i dont know what comp it is. the car is a 00 integra ls.
Old Mar 31, 2004 | 07:05 PM
m R g S r's Avatar
I'm pretty sure it's a p75.
Old Mar 31, 2004 | 07:36 PM
3.504's Avatar
Default Re: i need to connect meter wire (m R g S r)
obd2
GDM Z28
Nov 4, 2004 04:08 PM
tiresmoke
Apr 19, 2004 05:12 AM
importboi22
Nov 22, 2003 07:57 PM
u2civic1
Aug 1, 2003 01:11 PM
junglerunna
Apr 10, 2003 04:11 AM
