if i get an alignment do i not need a camber kit?
Old Mar 31, 2004 | 03:55 PM
es_squared's Avatar
Default if i get an alignment do i not need a camber kit?
noobish question, but im getting 16" C8s and my car is lowered on H&R race, 1.6 rear and 1.9 front. but yea.. cuz doesnt an alignment fix the camber anyways?
Old Mar 31, 2004 | 05:39 PM
1hotintegra's Avatar
Default Re: if i get an alignment do i not need a camber kit? (es_squared)
yea...but if ur car is lowered ur goin to need a camber kit to allow the camber to get to 0. if u dont get a camber kit when u get it alligned they will not be able to get it to where its supposed to be
Old Apr 1, 2004 | 10:06 PM
d16tuner's Avatar
on my 98 civ you can't adjust the rear camber anyway, so you'd at least need a rear kit if this also applies to you.
Old Apr 1, 2004 | 10:50 PM
iam7head's Avatar
Default Re: if i get an alignment do i not need a camber kit? (d16tuner)
how you gonna adjust/fix the camber without an adjustable camber correction kit?
you can run washers in the rear for the rear camber but the front you'll need something.
alignment is a MUST, your toe will eat up your tires alive if not
Old Apr 3, 2004 | 02:04 AM
D16Z6racing's Avatar
Default Re: if i get an alignment do i not need a camber kit? (iam7head)
fronts needs a camber kits more often than the rear. it doesn't hurt to have both though.
my crx needed just the front done. (2" drop)
my civic was fine, no camber issues. (1.5" drop)
hondaPINK
Suspension & Brakes
Oct 24, 2006 02:45 PM
blk94gsr
Suspension & Brakes
Feb 15, 2006 08:49 AM
fafsa
Apr 6, 2005 03:41 PM
fafsa
Apr 6, 2005 03:40 PM
