Im Having a problem with my accord!!!!!!!!!!!!!!!!!!!!!!!!!
Ok i have a 97 4 dr accord right my car is slamed with coilovers
and its extremly bouncy and im not shure if thats what it is but my windows dont go donw no more like sometimes when i hit the bump and it would bounce right it would begin to work again like if somehting got knocked lose
and my gauges would blink when it would bounce too also my tailights and all the inside dome lights dont work no more they would flash but they would alway turn back on now i guess whatever it was got kocked lose but now nuttin works all the dome lights inside the gauges the window and tailights dont work no more can anyone help me?
.......$20 says uve got some shitty *** ebay coil sleeve springs.....
1. ditch the shitty springs, and get new shocks as well (ones that can handle lowered cars)
2. replace any dead fuses
3. check battery/alternator to make sure all voltage is good
And buy a chilton's or helms manual. Ditch the coilovers, buy springs and aftermarket struts.
Check all fuses and replace if necessary.
THE COILOVERS ISN'T THE PROBLEM I WRECKED THE CAR AND EVER SINCE I WRECKED IT EVERYTHIUNG STOP WORKING THE ALARM THE EVERYTHING ELCTRICAL BUT BEFORE I WRECKED IT IT WAS BLINKING LIKE SOMETHING WAS COMING LOSE WHAT DO YALLTHINK IT IS
BUT THE COLIOVERS ARE NOT THE PROBLEM CUZ AS OF RIGHT NOW IM GONNA GET AIR SUSPENSION
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r2N »</TD></TR><TR><TD CLASS="quote">Please use lowercaps.
How did you wreck the car?</TD></TR></TABLE>
Proper grammar and punctuation wouldn't hurt either.
Sounds like you need someone with some electrical skills.
well i was hit from the back drver side door im guessing it made somthing come loose right?but what could it be?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordlooksick »</TD></TR><TR><TD CLASS="quote">
BUT THE COLIOVERS ARE NOT THE PROBLEM CUZ AS OF RIGHT NOW IM GONNA GET AIR SUSPENSION</TD></TR></TABLE>
Hold on you are saying that coilovers are not the reason the car is bouncing?? Ya they are...and if you are going to do air??have you ever ridding on air..its slightly more bouncy
but then again what do i know about air
well, guy, it's probably important that you told us that you were in the wreck... crashes have a tendancy to make electronics and things not work. it sounds like the suspension is aggrevating the problem, not causing.
welcome to H-T and try to talk like a normal human being. otherwise, let's see how long you last before getting banned.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordlooksick »</TD></TR><TR><TD CLASS="quote">THE COILOVERS ISN'T THE PROBLEM I WRECKED THE CAR AND EVER SINCE I WRECKED IT EVERYTHIUNG STOP WORKING THE ALARM THE EVERYTHING ELCTRICAL BUT BEFORE I WRECKED IT IT WAS BLINKING LIKE SOMETHING WAS COMING LOSE WHAT DO YALLTHINK IT IS
There ya go. Pretty easy to follow instructions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburner247 »</TD></TR><TR><TD CLASS="quote">
There ya go. Pretty easy to follow instructions.</TD></TR></TABLE>
best post evAr..
best post evAr..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baGged93aCcord »</TD></TR><TR><TD CLASS="quote">
best post evAr..
I would check and makes sure all your major grounds are clean and tight.
best post evAr..
Ok no one has actually answered my question they just keep going on and on about the caps and about the coilovers the bouncy ness is not the problem i need to know about the stuff that stop working like the dome ligts and stuff why did it stop working?
Well man it really sounds like you are going to need to chase your wires and see if you have any bad connections or check to make sure that you dont have any blown fuses..
The bounciness probably caused the problems you have. That is why almost everyone has said something about them.
pwn3d
pwn3d
The simple answer to your question is that your dome lights and stuff aren't getting any power. Why aren't they getting any power? I have no idea. Though from the description (bumps cause the power to come and go) I'd say you have a short somewhere.
What exactly isn't working on your car (what comes and goes)? Just your windows, dome light, and taillight?
What type of wreck were you in (frontal crash, side crash, etc), and how severe was it? Have you told your insurance company (or the insurance company of the other driver if he was at fault) that the crash has caused electrical problems and that you want them fixed?
As for the bounciness, if it isn't the springs / shocks, what else could it be? Did the bounciness begin only after the accident?
look,replace ur fuses, and if that does'nt work u have an electrical prob,sumthin could be loose but not to the point everything would be going out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01accordv6 »</TD></TR><TR><TD CLASS="quote">
I would check and makes sure all your major grounds are clean and tight.</TD></TR></TABLE>
I agree completly, I've had several cars come in with electrical problems caused by the bodyshop not cleaning the ground points properly after repainting the car. One bad groung can affect alot of systems.
I would check and makes sure all your major grounds are clean and tight.</TD></TR></TABLE>I agree completly, I've had several cars come in with electrical problems caused by the bodyshop not cleaning the ground points properly after repainting the car. One bad groung can affect alot of systems.
definately check ur fuses and grounds... i had a loose ground in one of my doors and the dome light wouldnt shut off and the speaker wouldnt turn on, and the door light on the cluster stayed on... take it to a reputable shop thats good with wiring i.e an alarm shop.
good luck
good luck
