What to lay down before glassing spare tire well?
Old Mar 31, 2004 | 08:12 AM
92BlackSi's Avatar
Default What to lay down before glassing spare tire well?
Do you guys use duct tape, garbage bags etc..?
Old Mar 31, 2004 | 08:18 AM
rcurley55's Avatar
New User
Default Re: What to lay down before glassing spare tire well? (92BlackSi)
There's a lot of things you can use. I like to use masking tape (the blue painter's tape works well) and then spray a few layers of PVA over it. You can use duct tape, but it will leave a very gooey residue as the heat from the fiberglass will break down the adhesive. Packing tape will work, and so will a combo of tin foil and masking tape.
Old Mar 31, 2004 | 08:58 AM
nOOber's Avatar
Duct tape then turtle wax.
Some guys I know just use wax, others just tape.
Old Mar 31, 2004 | 08:59 AM
92BlackSi's Avatar
what is pva?
Old Mar 31, 2004 | 10:21 AM
rcurley55's Avatar
New User
Default Re: (92BlackSi)
http://www.tapplastics.com/shop/product.php?pid=67& - pva
you can use it to help get the mold out of the car. Just spray it over the tape with a preval spayer
If you use tape, I'd try very hard to get the tape running all in one direction, and use the least tacky stuff you will find. I've NEVER had a mold just pop out. It always takes a little bit of coaxing on a complex part (like a tire well). So, one of two things must happen:
The mold must release from the tape - or - the tape must release from the car.
Old Mar 31, 2004 | 11:30 AM
4DRPIMPIN's Avatar
Default Re: (rcurley55)
aluminum foil... cheap, can't go wrong..
Old Mar 31, 2004 | 11:54 AM
92BlackSi's Avatar
Default Re: (4DRPIMPIN)
AL foil is more expensive than masking tape, but will this work just as well?
Old Mar 31, 2004 | 02:11 PM
rcurley55's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92BlackSi &raquo;</TD></TR><TR><TD CLASS="quote">AL foil is more expensive than masking tape, but will this work just as well?</TD></TR></TABLE>
I don't think a few dollars will break your bank
Working with fiberglass is expensive. The pro to foil is that it does a good job of protecting your car, and releases off of fiberglass fairly easily. The other nice feature is that you don't have to use much tape to hold it down, so there's less adhesive you have on the car.
Old Mar 31, 2004 | 04:14 PM
Goatsterrman's Avatar
Doing a spare tire mold I would use foil, there are times where it makes more sense to use other materials but in a spare tire mold I've found it best to use Aluminum Foil.
Old Mar 31, 2004 | 07:02 PM
turbod16y8's Avatar
Default Re: (Goatsterrman)
i would recommend a garbage bag and then sray wd40 on it. i did mine with a garbage bag with duct tape to hold it in place. works fine and easy to take off when it drys. foil will work too, but its a pain in the *** to take off. trust me.!
Old Mar 31, 2004 | 08:46 PM
rcurley55's Avatar
New User
Default Re: (turbod16y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbod16y8 &raquo;</TD></TR><TR><TD CLASS="quote">i would recommend a garbage bag and then sray wd40 on it. i did mine with a garbage bag with duct tape to hold it in place. works fine and easy to take off when it drys. foil will work too, but its a pain in the *** to take off. trust me.!</TD></TR></TABLE>
How is foil difficult to take off?...you just pull!!
I'd rather mess with that then a garbage bag that is difficult to get to lay flat. Then add WD40 to the mix - even worse IMO
Old Mar 31, 2004 | 08:49 PM
Yeah a garbage bag might be easy to remove but it's gonna be hard to do the bends of the well without having a bunch of wrinkles in the glass.
Plus...I'd feel kinda ghetto using a garbage bag and duct tape...lol???
Old Apr 1, 2004 | 06:27 AM
92BlackSi's Avatar
Once you get the base mould built, do you attach flanges to the fiberglass so you can have a solid edge to work with?
Also, how do you fasten the mold down in the wheel well once it is done? Or just let it sit in there?
Old Apr 2, 2004 | 09:55 PM
turbod16y8's Avatar
before doing the mold i would make a square frame wood.. then fiber the inside of it. ill show u my box. whats your email addy so i can send it to u. or your aim
Old Apr 3, 2004 | 08:47 AM
92BlackSi's Avatar
smithbling@hotmail.com thanks!
Old Apr 4, 2004 | 07:34 AM
ASHY-ELBOW's Avatar
i wax the well first, then a ;ight coat of spray glue, lay down plastic wrap and all done works like a charm everytime and takes a couple of minutes , vs taping the whole thing, but all methods above work , its just what works better for you
Old Apr 4, 2004 | 01:51 PM
eHoward's Avatar
Non porous release film.
TailZ
Detailing
11
Jun 8, 2011 11:45 PM
LifeMage
Feb 4, 2008 11:00 PM
will7
Jan 10, 2006 07:54 PM
idriveadelsol7
Apr 16, 2005 01:16 PM
00b18b
Oct 5, 2001 05:13 PM
