heat range for compression ratio of 11.5 and..,
Old Oct 24, 2001 | 11:57 AM
da6_b17a's Avatar
New User
Default heat range for compression ratio of 11.5 and..,
Sup,
My compression ratio will be 11.5 w/ my combustion chambers, valve faces and piston tops ceramic coated by http://www.polydyn.com. This will increase thermal efficiency but also raise combustion chamber temperatures. What plugs should I be using for this set up? I know about bcpr7es11 and bkr7en11, but is there a higher heat range? Thanks.
Old Oct 24, 2001 | 12:19 PM
FSTASNTZ's Avatar
Default Re: heat range for compression ratio of 11.5 and.., (da6_b17a)
I run 12.5:1 and use the stock heat range plug. No problems...
Jason
hatcht9x
Dec 9, 2009 09:28 PM
Behan
Jun 12, 2007 08:23 AM
Bnjmn
Jun 26, 2003 01:08 PM
ITR.00-1282
Mar 30, 2003 09:04 AM
wm5holla
Jan 7, 2003 07:06 AM
