Smoke inside cylinder head???
Old Mar 31, 2004 | 07:47 AM
hybridturtle's Avatar
Default Smoke inside cylinder head???
I have an h22a in my accord, and had it for about 2 years now. But lately its been running really weired, it keeps dying on me when I come to a stop and let it idle. And I've been noticing that I hav been buring more oil then usual as well. And yesterday I tried to figure out what was wrong and unhooded my intake and the hose that goes from the valve cover to the intake. Then when I started the car, smoke came out of that hose.
I was told that I might have a cracked piston
Has this happend to anybody? Any second opinions?
Old Mar 31, 2004 | 08:16 AM
Sephro's Avatar
Default Re: Smoke inside cylinder head??? (hybridturtle)
have you noticed any smoke comming out the exhaust?
Have you noticed your coolant levels dropping??
I'm thinking it might be a blown head gasket.
Old Mar 31, 2004 | 09:22 AM
Default Re: Smoke inside cylinder head??? (Sephro)
the coolant hasn't been affected, I'm not sure if there is smoke comming out of the exhaust and if there is it must be very little because I haven't noticed it.
Old Mar 31, 2004 | 10:46 AM
Sephro's Avatar
Then do a compresion test. That will tell you if you need to rebuild. Do a wet and a dry test.
Old Mar 31, 2004 | 12:34 PM
weavesprelude's Avatar
if your burning alot of oil and its you see white smoke coming out of the exhaust it could possible be the piston rings are bad. Do a compression check to see if you have compression.
Old Mar 31, 2004 | 02:59 PM
noble4ws's Avatar
valve guides?
pepperdk
Honda CR-V & Element
Jun 11, 2015 03:10 PM
EEWagonBol
Mar 31, 2009 07:43 PM
Redprelude98
Nov 25, 2008 10:42 AM
asubennett
Nov 1, 2004 07:27 PM
5thgen
Mar 24, 2003 07:15 AM
