timing belt off a tooth?
Old Mar 31, 2004 | 07:36 AM
japspecjohn's Avatar
Default timing belt off a tooth?
Im about to do my timing belt on b16a...... lined up the crank pulley top dead center..But the cam lines arnt lining up...Does that mean my old belt was off a tooth?
Thanks
Old Mar 31, 2004 | 07:39 AM
Default Re: timing belt off a tooth? (japspecjohn)
also I ordered the 99-00 b16a2 timing belt...that works right? I saw some one said it did just double checking..
Old Mar 31, 2004 | 02:19 PM
bump
Old Mar 31, 2004 | 02:32 PM
Redline130's Avatar
I know that DOHC heads are harder to line up the cams to TDC, especially if you don't have that tool that holds the cams in place. I had the same problem with my B16, the intake cam kept moving while I was trying to get the belt on. Takes a little patience, but just take your time and make sure that both cams are lined up.
f20beme
Apr 13, 2015 04:34 AM
purgat0ry
19
Aug 22, 2012 04:27 AM
turboedsupe
Sep 19, 2008 04:32 PM
hondachris1994
12
Aug 23, 2008 12:17 PM
dwn4cause
Jun 20, 2005 09:10 AM
