SOHC VTEC swap in a Civic Dx converted to obd1
Old Mar 31, 2004 | 02:46 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default SOHC VTEC swap in a Civic Dx converted to obd1
technically how hard is the swap.
I know I have to convert the dpfi to mpfi
but i want to convert to obd1 since that is sure to pass inspection
any help
thanks any links from other sites
its hard to search here
i came up with misc
Old Mar 31, 2004 | 08:05 AM
Aragorn's Avatar
Default Re: SOHC VTEC swap in a Civic Dx converted to obd1 (MugenHonda)
Not that bad....... Add 4 wires for the MPFI conversion, buy a OBD0-OBD1 conversion harness from Blown90hatcH on this board and add 8 more wires with that harness. You need a 4 wire O2 sensor and any plugs that are different (OBD1 injectors, dist, Vtec solenoid, Oil pressure, etc.). You need a P28 ECU. You use your stock mounts, tranny, and axles. I bought a SI tranny for the gearing and better acceleration, but that isn't technically needed.
historic4thewin
May 30, 2019 04:10 PM
Zack Gunther
13
Aug 5, 2014 09:04 AM
m3kid
Apr 21, 2012 06:30 PM
88zchatch
15
Mar 20, 2009 12:06 PM
Dohc 4door Rye
Feb 10, 2006 11:36 AM
